m-lud
Stainless
- Sep 4, 2016
i have a recent problem with a sticking clutch. I take off a access plate and loosen pressure plate bolts and bump the starter with it in gear. Coil wire off. This has worked but last time stripped the friction material off of one side.
I put a 4x4 wedged in to hold the peddle down when parked and it still sticks ??
The plate is made in mexico so its been changed.
I usually change the pressure plate and throw out bearing but not this time. Ill block the pressure plate and flywheel with 320.
Does anyone have a aftermarket parts source. Rather not pay Hyster prices. Wet clutch.
5 years and first fail. Cant live without it.
12" clutch plate, 1 1/8" root diameter spline , 1 3/8" 0uter diameter spline. 10 spline shaft.
