Hyster Fork Lift OLD S30 Help !!
Rick_pr
Aug 7, 2021
I have a old Hyster Forklift S30 models with problem brakes and when remove the front axle leak fluid pink color?
Any information of Part Manual? What Fluid use this model? Need order the brake shoes and cylinder for this
That's how it is. I don't know if the gear oil was mixed with water. I think was oil mix water. Maybe for long time storage !!
But inside have a pink fluid. Also when check the dipstick mark the pink fluid.
Did you mean the dipstick on the engine? If it is pink in the engine also is sounds like someone used the same pink oil in everything. Odd for engine oil and gear oil to be a pink color.
Yes but who could be dumb enough to use it in the diff and engine? :nutter:
Pretty sure thats a transaxle, not just a diff. Can't check because its a ways away but think my Daewoo lift uses ATF in the transaxle, and my old Clark came to me with ATF in the transaxle, it does leak, guess what I refill it with? Both of my lifts have a dipstick for the transaxle.
My Hyster Forklift have dipstick in the Transaxle.
What type of Fluid you use to fill your Transaxle?
