Hyster H200HS Forklift Transmission problem.
Likes Likes:  0
Results 1 to 4 of 4
    Oct 2019
    AUSTRALIA
    Default Hyster H200HS Forklift Transmission problem.
    I have recently purchased an old Hyster H200HS C7S-1553A Forklift. It has the 'monotrol' on the throttle and a gear selector lever to the left of the steering wheel that operates a spool valve on the transmission with 4 detent positions.
    If I select the furtherest forward position the forklift moves forward, the 2 middle positions it actually locks up, the furtherest back it moves forward.
    The monotrol seems to be not working as it will only go forwards even when reverse is selected. I loosened the 3 pipes on the monotrol, the oil flow seems to change from one to the other when forwards/reverse is selected and oil flows out of the supply pipe all the time.
    Has anyone got info/parts/service manuals on these transmissions? Some info on clutch pressures etc would be very helpful.
    I suspect a clutch pack may be locked up/worn out.
    Thank You.
    Jul 2009
    Peoria, IL
    11,712
    51
    8969
    Sounds like forward and reverse are engaging at the same time. But, I don't have any info on the trans. My forklift dealer has always been very helpful with info.
    Dec 2009
    N. Calif.
    135
    10
    57
    I hope this is readable.
    Link.
    Hyster Transmission - Album on Imgur
    Oct 2019
    AUSTRALIA
    Thank You Keyster, that diagram was very helpful.
    Has anyone got a parts diagram for this transmission?
    Thanks.
