You will be very lucky to find a manual online.Forklift manuals dont seem to exist online,for some reason.....All forklifts are a problem to work on......if you need to take off the mast,you will need heavy lifting gear,or another forklift...Some machines its easier to take off the counterweight and pull out the motor.....incidentally,some small Hysters are TCMs....The manual will be ultra expensive,and may well be a pile of update bulletins...I worked on many forks,Ive never seen or owned a manual....nor needed one.They are straightforward,just impossible access.
