Hyster S60 ES stuck in neutral
Results 1 to 6 of 6
    Jun 2016
    Virginia
    916
    472
    109
    Default Hyster S60 ES stuck in neutral
    Friend’s Hyster S60 ES is stuck in neutral, he doesn’t have the manual. How to fix?
    Sep 2016
    Missouri
    781
    668
    221
    Is there a safety interlock that wont let you put it in gear. Clutch peddle ,brake peddle. Other shift lever in a certain position. You may want to check the adjustment of any shifting related micro switches. I'm not familiar with your model.
    You may want to be more specific on the type of transmission
    Oct 2005
    western washington state
    3,548
    2296
    3535
    that model usually featured monotrol shift brake pedal--red rubber pad typical
    momentary switches connected to tilting pedal--if any wire is disconected it usually remained in neutral
    transmission was totally solenoid controlled
    again--any wire loose or disconnected would disable
  4. Likes mllud22, Ox liked this post
    Oct 2017
    538
    138
    144
    On our Hyster (don't remember the model, but pictures on google look identical) there is a mechanical linkage between the brake pedal and transmission that puts the transmission into neutral once you press the brake. This is to allow you to press the gas pedal for using hydraulics while stopped without shifting into neutral. I personally think it's a pain in the ass, and can come out of adjustment (along with making it impossible to stop and start on a hill without rolling back).
    Many people choose to disconnect the linkage and tie it back. However, the linkage is spring loaded towards the neutral position, so if however it was secured moved it will tend to slip to neutral. Also, as the brakes wear and get crappier and crappier as forklift brakes tend to do, the pedal position the corresponds to a dead stop changes relative to where it goes into neutral.
    A picture of the pedals and transmission with the floor pan removed will help determine if this could be related to the issue.
    Also check that the interlock switch on the engine cover is functional. This is the only shifting interlock that our forklift has.
    Dec 2009
    N. Calif.
    135
    10
    57
    If I remember correctly.
    There is a small slave cylinder on the side of the transmission control valve that works off the brake system.
    If the transmission plunger leaks and gets atf onto the slave piston cup it will swell and not release the inching system.
    You can manually push the slave piston back to see if that is the problem.
    Try and use factory brake cups if you need to replace it.
    They are very small and need to move freely.
    There may be neutral switch on the park brake.
    Make sure that is working.
    Dec 2009
    N. Calif.
    135
    10
    57
    These forklifts used the same pump for steering and transmission.
    If the power steering and transmission are not working, the pump losing its prime is common.
    The dipstick level will look fine, but no fluid is moving. Its all in the sump.
    Overfill and loosen the vent plug on the top of the steering / transmission pump to bleed the air out.
    Recheck fluid level.
    I ran these overfull with no problem.
