I have a Hardinge HLV lathe and a manual mill (Abene VHF-3). Would it be ok to rent a storage unit (pods or similar) and temporarily put the machinery in there? I'm concerned about max floor load (they don't provide any specs for that). What do people do in such situation?
Those tools are NOT heavy point loads. Any of the many ground level slab units here (I rent one myself) and SPECIFICALLY chosen
as ground-level and direct vehicle access, you can JFDI.
I say again "ground level" and direct vehicle access. They are in demand for convenience, go fast, so you may have to shop, drive further, and pay at least a modest premium. Place I am in is 100% ground-level drive up roll-up doors... but was nearly FULLY BOOKED accordingly.
Well worth it as to MOVING the goods!
FWIW-not-much, What has killed more floors, above ground and catastrophically now and then, believe it or not ... is stored PAPER records.
One sheet at a time? Yah. Light enough?
But man does it ever ADD UP! And then they get WET?
As to the epoxy job itself?
Have you cranked-in
ALL the costs and the "payback" for them for such
realistic gain as it MIGHT give you... over the periodic renewal of the simpler paint, do-able in increments with far less "impact", each?
