installing an army type hoist
Likes Likes:  0
Results 1 to 5 of 5
    Apr 2004
    Modesto, CA USA
    6,733
    1116
    Default installing an army type hoist
    How would you install a army type hoist on a existing gantry beam. This is the type of hoist with the trolley integrated as one piece with the hoist. Would you take the wheels off or at least increase the span so it can go up over the lower flanges. Or is there something I am missing.
    Bil lD
    Aug 2012
    California, Central Coast
    3,323
    2153
    1293
    Those are called low headroom hoists, do you have pics? I guess you can not slide it on from the end of beam so I would remove wheels from one side and reinstall them when hoist is in position. Remove both sides if needed.
    Jul 2004
    Houston, TX USA
    29,470
    This one got installed that way (wheels off) about 30 years ago
    May 2008
    Minnesota
    679
    350
    225
    Instaling my CM 1 ton army trolley hoist was just a matter of removing the wheel. I don't recall anything spectacular about it all. Probably a bit harder if you are talking about a 10 ton hoist.
    Oct 2009
    Olympia, Wa
    607
    301
    172
    I have 2 army style hoists, a Chester and a Wright. The Chester you just remove 1 side of wheels, its simple. The Wright is a bit more complicated, you have to split the hoist in half and reassemble but still pretty simple.
