lifting misadventure
Results 1 to 13 of 13
    Oct 2005
    western washington state
    3,592
    2422
    3639
    Default lifting misadventure
    this weeks project is restoration of S 60 genie boom lift
    it rode a miller type trailer into a roadside gully when the pintle hitch fractured /separated from Freightliner dump
    two Peterbuilt recovery vehicles winched the genie onto a beaver tail trailer and in process shredded ground control +platform and aerial control
    right rear wheel and tire mangled
    now at my shop I lift rear of machine--to remove tire and rim--genie rolls forward planting frame in ground
    I planned to fab toe jack but implemented Chisholm Moore ratchet jacks in my inventory--these were bespoke made for US military --gang of 4 would lift 20 foot conex laden at 48K
    I chopped 16 inches off top of one CM unit and placed under rear frame--these jacks are rack and pinion--it lifted all 12,000 lbs with around 20 lbs crank handle force
    walking beam and bottle jacks used for added insurance
    so the torq hub planetary is ready for new rim+wheel
    and I will then focus upon upper and lower controls plus new platform
    Attached Thumbnails Attached Thumbnails 100_2896.jpg   100_2897.jpg   100_2898.jpg   100_2904.jpg   100_2905.jpg
    Oct 2005
    3,592
    2422
    3639
    look closely at foreground pic 4--a 20 ton bottle jack is mashed from swing axle drop--I was under machine and impact with bottle jack allowed Genie to roll forward with only a minor head strike--small price to pay
    better to be lucky than smart
    last pic is what is left of hub piloted rim which will be joined to new rim for precise fit
    Attached Thumbnails Attached Thumbnails 100_2906.jpg   100_2907.jpg   100_2908.jpg   100_2909.jpg   100_2910.jpg
  3. Likes dalmatiangirl61 liked this post
    Jun 2016
    New York
    1,570
    882
    677
    WOW! glad you are OK, but where to start with "whats wrong wrong with this picture" soft ground is no place to attempt this kind of maneuver!!
    Mar 2013
    Surbiton, surrey, UK
    1,622
    1997
    1039
    Any day you walk aways a good day. Glad you wernt hurt.
    Jul 2008
    Philadelphia
    1,948
    515
    445
    Default One of those days
    First let me say I am glad know one was injured, and yup shit happens.
    I agree with Cyanidekid, jacks + soft ground =
    Having been in the soft ground Jack spot I can throw out a few suggestions.
    1 Large steel road mending plates (~3/4-1" thick I don't know the weight of the Genie)with as large a foot print as is manageable under the Jack(s). The scrapper we use has loaned us these big heavy plates on the 1 or 2 occasions we need them.
    2 Place cribbing under key points as you jack, I always anticipate a jack(s) failure.
    Sorry to see what happened, be safe but looks like you well on your way outta the mess.
  7. Likes cyanidekid liked this post
  8. #6
    Oct 2005
    3,592
    2422
    3639
    Default more of the story
    the low profile 20 ton bottle jack--the mashed one--was seated on doug fir plank 3 in thick 10 in width 24 in length--compressive strength of doug fir around 7000 psi --load this jack supported 12K ---- total genie weight 25K
    so in theory the plank should have supported the jack base--but it failed when two other jacks were removed --interior of plank contained multiple beetle tracts
    I had a slab of 1.5 in thick kraft paper phenolic sheet 4 foot square--weight 100 lbs and yesterday sawed this into 4 pads for jack support--for years I have carrier one phenolic pad in pickup for jack base --flat tire contingency-- phenolic compressive strength 35K psi
    no more wood for jack bases
    but real issue of boom lift roll off is 10% down sloping grade lift is situated---normally planetary drives on 4 wheels would act as braking mechanism--but each one was defeated by inversion of end cap of torque hub drive---so they free wheeled-- the extraction crew reversed the end caps on all wheels-- and on my second attempt at elevating the lift I attached a hold fast line to dead head--my 26K weight champ lift truck--and chocked wheels of champ--so far this system works
    pic illustrates torque hub planetary with end cap which free wheels drive when reversed
  9. Likes cyanidekid liked this post
  10. #7
    Jun 2016
    New York
    1,570
    882
    677
    Quote Originally Posted by JHOLLAND1 View Post
    THREE lessons to be learned here,
    1) those hubs can be easily converted to freewheel, (or possibly can be stripped out internally)
    NEVER ASSUME THEY ARE PROPERLY FUNCTIONING WITHOUT TESTING (on an old salvage unit)
    2) WOOD IS A NATURL, VARIABLE MATERIAL. AVOID RELYING ON A SINGLE PIECE FOR A CRITICAL LIFT, AND LOAD IN COMPRESSION ONLY
    two examples of better practice; proper cribbing uses multiple pieces of wood, and that is totally fine, and under the pads on crane outriggers they use plywood pads on asphalt, but they are square and uniformly loaded, you effectively beam loaded the one board.
    3) SOFT GROUND IS INHERENTLY AN UNKNOWN, ALWAYS INCLUDE AT LEAST A 5 TIMES SAFTEY FACTOR.
    a 1 X 1' ground pad is just not enough to lift 3-4 ton on soft ground, id think 2' X 2' is a bare minimum, and the pad has to spread the load over the entire surface (assume you have a hole under the middle of the pad. for that id think 5/8" thick steel is needed at minimum. or something like two sheets of 3/4 ply at 2' sq. and a 1.5' sq. of 1/2 " steel on top.
    again, really glad you are ok, and thanks for posting, good to know about those hubs in particular!
  11. Likes JHOLLAND1, tim9lives liked this post
  12. #8
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,093
    904
    716
    Inspect the boom on that think carefully before using it.
    I almost bought one for insurance salvage after it rolled off trailer and over. The booms on them are over-reinforced on bottom for the lift cylinder lug, but the webs (sides of the box-section) are thin, thin, stuff, and once they buckle even a little the boom will fold.
  13. Likes JHOLLAND1 liked this post
  14. #9
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,244
    1126
    675
    Quote Originally Posted by magneticanomaly View Post
    Was it you, or OP, that asked about my lift last year? With OP's description of the damage, I was thinking it was same machine, maybe not?
  15. #10
    Mar 2007
    2,093
    904
    716
    Not mine, DG61. The one near here got bought by a neighbor, who cut it up and will be using the boom sections for culverts.
  16. #11
    May 2008
    Minnesota
    699
    356
    235
    If you don't kill yourself getting it fixed, you'll really like having the lift. I picked a cheap Genie S40 lift and I absolutely love it. It was cheap, so it has issues. But getting to wherever you want without using a ladder is awesome.
    As I am sure you have found, Genie has every manual for the thing right on their website. I've found that buying the parts factory direct is the most expensive, but there are a multitude of dealers selling OEM parts with dramatically different prices. $40 switch from genie might be $25 from one dealer and $6.50 from another.
    I get to rebuild the anti-oscillation cylinders on the non-steering axle of my lift. As I've acquired more heavy equipment I invested in a pair of 20 ton jack stacks with big bases. And a 20 ton air over hydraulic jack. On flat dry ground with sufficient bearing capacity, lifting is so easy. Just put the 20 ton jack in the middle of the axle, lift the whole thing, and then set jack stand(s) and the height and location desired.
  17. Likes JHOLLAND1 liked this post
  18. #12
    Oct 2005
    3,592
    2422
    3639
    Default donor wheel rim
    unable to locate needed 15x19.5 inch tire and rim with required 11 inch hub bore to accommodate 11 inch torque hub planetary construct in effect on this early series Genie S60
    scrap yard partner donated proper rim and tire assembly removed from LiftAll
    but 9 inch bore was present
    so---I cut mangled Genie rim apart--cleaned up on Romi lathe--then welded Genie hub plate to donor LiftAll rim
    cut away obstructing 9 in donor plate and drilled 10 new penetrations thru donor rim allowing hub piloted mating with 11 in Genie drive hub
    all in all---savings of $1000
    pics illustrate Mitsui Seiki jig borer
    reground 1-1/2 in counterbore cutter to angled counter sink required to seat lug nuts
    YouTube
    Attached Thumbnails Attached Thumbnails 100_1527.jpg   100_1518.jpg   100_1524.jpg   100_1529.jpg   100_1531.jpg
  19. #13
    Mar 2009
    Eureka, CA
    3,773
    752
    1306
    Arrgh!
    Stuart
  20. Likes JHOLLAND1 liked this post
