Looking for recommendations on skates and toe jacks
Likes Likes:  0
Results 1 to 5 of 5
    Nov 2003
    Phelps, NY, USA
    1,683
    1130
    346
    Default Looking for recommendations on skates and toe jacks
    I'm in the process of relocating and purchasing some new to me equipment for my shop and am interested in getting some toe jacks and skates to better position the machines. The largest machine I will be moving is a 20 1/2 X 54" Powerturn Lathe at ~9,000 lbs. The other equipment includes a 48" press brake, Bridgeport, drill presses, grinders, air compressor and a few other odds'n'ends.
    Any recommendations for reasonably priced and OK to use toe jacks and skates? The equipment will mainly be used for this move and over time may see some use moving some additional equipment.
    Feb 2015
    Ohio
    527
    136
    137
    My opinion is that a cheap (Jet) toejack is going to be good enough for limited use. The skates on the other hand require a certain level of quality to perform well. Buy the best skates that you can afford, and enjoy an easy roll.
    Apr 2004
    Modesto, CA USA
    8,536
    1631
    You might consider renting big ones for the 9,000 pound load and buy smaller cheaper ones to keep for everything else. I have no idea how much. a press brake weighs, regardless of size. So I may be completely wrong.
    Bill D
    Oct 2014
    Maine
    1,313
    259
    628
    Vestil for skates. I have, I think, the 3 ton units. With two fixed and two steerable skates, moving heavy things is quite easy. I got mine from MSC.
    TEMCo for a toe jack. Nothing fancy, but it does what it's supposed to. Available direct or through Amazon.
    Dec 2012
    Se Ma USA
    2,196
    179
    1198
    Move very slowly and check the skates every 10 inches. Try to use only three if possible. That way one will not become unloaded when you are not looking.
    Press brakes are stupid top heavy. Bad stuff can happen quick. Best to put skates on one end, lift from the top on other end with a stout forklift. And cut some good size wedges from hardwood (even green hardwood) to slide in while jacking. Slide them under as machine gets raised. This will keep the brown spots out of your pants if some other part is not up to the task.
    Good luck.
