Spud
- Jan 12, 2006
- Brookfield, Wisconsin
Anyone here use / used a Ram Promaster 3500 chassis cab ? Specs say the payload is 5170 lbs , but it only has 5 bolt axles front and rear, and this is a front wheel drive only vehicle.
Something that has me confused, the Ram site says GVWR for the chassis cab 3500 is 9350 lbs and GCWR is 11,500 lbs. I thought GVWR was the weight of the truck + cargo + occupants while GCWR was the total weight of the truck + loaded trailer . So how can the GCWR be only 11,500 lbs when the specs say it can tow 5100 lbs. Shouldn't GCWR be 9350 lbs + 5100 lbs ?
2021 Ram ProMaster(R) Specs | View Dimensions & More
