Magnetic Lifting Unit
Results 1 to 19 of 19
    Aug 2002
    West Unity, Ohio
    24,870
    5091
    7673
    Default Magnetic Lifting Unit
    I have several large burnouts to lighten up, and I told the guy that [off the cuff] I wasn't sure how I'd handle them as they don't lend themselves well to any way that I would generally handle them. He said that he had a magnet that could handle them.
    They are 1850# burnouts!
    Yeah, I've seen them advertised for years.
    Walked past many booths at the shows that were trying to sell them, but they always scared me, and so far I haven't needed them...
    Well, I get over there to pick up some blanks and he had the magnet there and he knew that it picked it fine from the mill-rolled surface but to toss it in the lathe - I need to pick it from the burn-out side. We wondered how it would hold there?
    Unit was rated at 1000kg, and we picked 1880# from the burn-out side, AND he bounced the forks to see if she'd hold.
    And she did!
    To say the least - I am amazed!
    I have several of these blocks to turn into chips, and I don't need to keep this guy's mag as he may want it at his shop...
    So I looked into buying one for ourselves.
    The one that he has is Earth Chain brand and is made in Taiwan.
    I checked to see what McMaster had, and they carry Industrial Magnetics brand, but the 2500# unit that they have is imported from China. However Industrial Magnetics does have a USA line, but it only goes to 1200#, and is about 2wice the bucks.
    Before I buy sumpthing, I would like to see what else [if anything] might be available - Made in USA/Canada that someone might recommend?
    Think Snow Eh!
    Ox
    Dec 2008
    New York
    9,995
    2593
    they have different capacities for flat and round. if surface uneven AND if surface not thick capacity is less often much less. usually I get a bigger one for heavier stuff. they come in different sizes and capacities. little ones you can pick up. bigger ones are too heavy for a person to normally pickup
    Oct 2005
    14,075
    Eriez..made down the street ( well the headquarters is)
    Eriez - SafeHold Permanent Lifting Magnets
    By the way 1800lb is pretty small, put 20 of them in a grid to pick up all the burnouts at one time (after the skeleton is cut off and removed)
    BTW even though the mag will pick up the piece, carefull when you get it near the intended chuck/vice....might squash your fingers.
    There is an attraction going on....
    Aug 2002
    West Unity, Ohio
    24,870
    5091
    7673
    I have found several different companies selling these, but all seem to be made in Asia.
    (Eriez included)
    I'm guessing that the permanent magnet thing is partially to blame for that?
    No skeleton left from these burnouts. They are rectangle.
    Think Snow Eh!
    Ox
    Oct 2005
    14,075
    I have no way to verify where they are made, I assume you checked ?
    There's always electricity ....
    Eriez - Bi-Polar Lifting Magnets
    "Bi-polar" I thought that had a switch marked "Suck/Blow"....
  6. Likes ronf liked this post
    Aug 2012
    California, Central Coast
    3,041
    2111
    1168
    One reason they do a good job picking up your burnout is it is a solid piece with lots of iron, thin wall tube or sheet wont have as much iron for the magnet to "grip".
    My old Jancy mag drill is rated for 1200 lbs pull off, but only if stuck to 1" plate or thicker, it's easy to pull it off of 1/4" plate when drilling.
    Jun 2013
    Northern Il
    1,244
    661
    1184
    Walker Magnetics is based in Ct. and manufactured in Oh.
  9. #8
    Jan 2019
    Tennessee
    350
    93
    94
    EarthChain is better than the no names, by far. It is denser?. Our earthchains are all half tons, and one cute 600# (super handy) and they are able to lift almost the same as the 1000kg Chinese ones if the surface is not perfect (steel shop perfect, flat and blasted).
    Never use four on a plate, one will always have lite load and release - then all fail. Three is best. Point relatively same direction, pipe (thin wall to weight) will not pick up at all with magnets pointing opposite hand.
    Once you get magnets you will forget the dark ages of rigging everything just to position or stack.
  10. Likes cash liked this post
  11. #9
    Aug 2002
    West Unity, Ohio
    24,870
    5091
    7673
    I understand why not 4 skates, but I don't git the 4 mags?
    Are you saying that one has a light load and another one has a heavy load - and THAT fails?
    You must not be using looped straps for this to be an issue?
    Not that I am planning to buy 4 mags any time soon, but ....
    Absolutely thank you for the Earth Chain comparison!
    Think Snow Eh!
    Ox
  12. #10
    May 2011
    New Jersey
    1,806
    167
    981
    About 9 years ago I was lifting a 3x4x144 piece of 17-4 on to a saw with a mag unit well within limit. Long story short, it let go with a bang...luckily I didn't get hurt but got the blood flowing.
  13. #11
    Aug 2002
    West Unity, Ohio
    24,870
    5091
    7673
    A quick search doesn't produce anything with much info on this, other than to say that 17-4 and 17-7 are not quite the same magnetic value, but I didn't find any scale of comparrison to say - A36.
    Only that 17-4 "is magnetic", but it doesn't say "how" magnetic.
    I know that 416 is lightly magnetic, so I know that it's not a yes or no thing with all having the same pull value.
    Think Snow Eh!
    Ox
  14. #12
    May 2011
    New Jersey
    1,806
    167
    981
    Think Snow Eh!
    Ox
    I don't know either
    It was what they used for it. I don't know why this one decided to come off, nor do I remember the specific circumstances. I do know that bar was heavy lol
  15. #13
    Jan 2019
    Tennessee
    350
    93
    94
    Think Snow Eh!
    Ox
    my bad, one gets overloaded and fails (dyslexic brain moment) , the rest follow fast with the shock load. chains and hooks, sometimes looped, depends on which crane(some have long chains so you have to loop for clearance). even with spreader bar 4 magnets fail, when three have no issue, sans spreaders too.
    Beams, pipes, tubes, flats, channels use one or two, pointing same direction.
  16. #14
    Aug 2007
    Wisconsin
    2,055
    1061
    903
    Our Shop lives on these lift magnets, we have had several different brands. For the most part they all function with no issue.
    I as you wish more of these were made in the USA, but they are not.
    One USA brand I know of for sure is Industrial Permanent Magnetic Lifters | Eagle Lift | AWS
    I have used this brand of over 10 years. Our only problem with these is the guys beat up the handle pretty bad over time. It is not as good of a design as some of the others, you need to pull the handle out to release it. Here is an older video of this magnet in action.
    YouTube
    For larger size magnets I have some electro perm magnets- this lifts up to 6600 lbs. My video was so good the company used it for their promo, I am still waiting on the royalty checks.
    Bat Grip | Tecnomagnete
    As of recent my managers like the Earth Chain Products, they seem to hold up pretty good to the everyday abuse in the shop.
    Lifting Magnet of Earth-Chain Lifting Magnets Manufacturer
    As you can see from the beginning of this video we use these to handle our plate work daily.
    YouTube
    I may be wrong- but I think a reason most of these magnets are made in China is the availability of the material needed for the permanent magnet, but this is not confirmed.
  17. #15
    Aug 2002
    West Unity, Ohio
    24,870
    5091
    7673
    I am under this impression as well.
    Too bad that I didn't find the USA model sooner.
    I have spoken for an Earth Chain unit that I found used, and a chum is s'posed to pick it up for me in Denver Town today or Tuesday.
    Thank you for the input!
    Think Snow Eh!
    Ox
  18. Likes cash liked this post
  19. #16
    Feb 2007
    Aberdeen, UK
    3,391
    1191
    1256
    We have a lot of these too. By far the best ones I've used are the Eclipse Ultralift Plus. They have a safety mechanism that locks the magnet in the engaged position when there is load on the lifting eye. Just about all others I've seen rely on the handle and the over-centre force of the magnet to keep it engaged.
    We have also had two minor injuries over the years from cheaper 2Te units where the guys underestimated the spring force of the handle and got whacked by it when they disengaged the magnet. The Eclipse mechanism requires much less force on the handle to engage and release the magnet which mitigates this kind of problem.
    The Eclipse magnets also come with a test shim that you put between the load and the magnet to test if it's a safe lift. If the magnet takes the weight of the load with the shim, then it's safe to remove the shim and lift.
  20. Likes digger doug, Tyrone Shoelaces liked this post
  21. #17
    Oct 2012
    304
    122
    137
    2 things to consider with magnets - overhang and thickness.
    Most magnets are rated for pull on a 2" plate. The rating drops off with thinner plate. Ex: An Eriez magnet that lifts 2500 lbs at 2" thickness can only do 900 lbs at 1/2" thickness.
    Thinner plates can sag from too much overhang and peel off the magnets.
    https://www.eriez.com/Documents/Lite...ift-Magnet.pdf
  22. Likes digger doug liked this post
  23. #18
    Dec 2012
    Se Ma USA
    1,434
    110
    810
    I have some name brand magnets and some bought on Amazon. All look to be from the same factory/design. Nothing as heavy as you need but they sure come in handy.
  24. #19
    Apr 2006
    Manchester, England
    7,977
    1116
    4964
    Quote Originally Posted by gregormarwick View Post
    I know exactly what you mean about getting a crack off the handles !
    Regards Tyrone.
