Moving a House Back and Forth Not for the Faint of Heart
Results 1 to 11 of 11
    Oct 2005
    Wilmington DE USA
    2,293
    375
    489
    Default Moving a House Back and Forth Not for the Faint of Heart
    I've seen buildings moved before, helped raise a few to put basements under without moving the house.
    These guys are just......nuts
    But have some interesting equipment
    Turn the sound down/off
    House Move Ponsonby - YouTube
    Aug 2005
    Tucson AZ
    6,713
    10773
    3218
    Tractor is a right piece of work, Western Star with right hand drive, Dayton wheels on the steer and Budds on the drives (planetary at that). The work clothes are impressive, like hot pants.
    Oct 2009
    Oregon
    5,943
    6433
    3309
    What might a house like that weigh? 60,000+ lbs or so?
    I'm surprised nothing failed in that move- The way they showed the trailer tires squished about as flat as you could get them at several points during that move.
    Seemed proud to show the moments where beams were deflecting heavily and workers in the position to be squished flat if anything goes wrong.
    Way too many corners cut for me.
  4. Likes tdmidget liked this post
    Oct 2010
    Oregon
    5,681
    5517
    2156
    I was pretty freaked out until I started thinking about the gear as "mobile bridge" instead of "truck". Is that sort of rig standard in house-moving, or do outfits like Easy Moves design their own custom equipment?
    Cameraman thinks he's Michael Bay (and that's not a compliment). There were places in that video where I literally could not tell if the camera was on the fritz or if the video editor was amusing himself.
    Crew definitely has big brass balls. I would not want to be the driver of the rig on top in a job like that.
  6. Likes Garwood liked this post
  7. #5
    Dec 2012
    AUSTRALIA
    4,260
    20
    1526
    yep ,the million dollar hydraulic rigs are standard in housemoving .....generally allow a house to be off a site and onto the road in one day (and night)..(house on stilts,as yanks call them).....The house I live in now was moved in two pieces by GMC 6x6 trucks ,on trailers made from miscellaneous truck axles , the structure of the trailer long timbers cut from the bush......All hard work by men who drank a lot of beer.In those days ,none of the vehicles were registered (or roadworthy),and the escort cops would each get an envelope full of cash.
  8. #6
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,819
    2898
    1793
    Quote Originally Posted by tdmidget View Post
    I knew it had to be down Australia way by the shorts (hot stuff btw), only place you will see tight shorts like that on a guy in USA is a Chippendales show, or a gay bar, problem is its the same guys!
    Rather ironic that the company name is Easy Moves, job looks anything but easy.
  9. #7
    Sep 2009
    Phoenix,AZ
    2,030
    3218
    543
    I think the cameraman was a spastic Raccoon !!!
  10. #8
    Nov 2007
    marysville ohio
    10,629
    2971
    7333
    Camera work was so bad I had to turn it off.
  11. Likes digger doug liked this post
  12. #9
    Aug 2019
    77
    92
    I love that trailer, it can basically climb stairs. My favorite part was when the boss had his head between the rear axles of the semi while it was moving at the edge of the "cliff".
  13. #10
    Aug 2002
    West Unity, Ohio
    27,296
    7713
    9512
    Call me when they get some "steadying" software enabled.
    Think Snow Eh!
    Ox
  14. #11
    Oct 2009
    Oregon
    5,943
    6433
    3309
    Quote Originally Posted by sfriedberg View Post
    That guy has a pretty easy job. All he's really doing is switching the brakes on and off, turning the steering wheel and running a hydraulic valve to control the fore-aft movement of the hitch.
    I don't think at any point in the video they used the engine/transmission/rear tires to move that truck.
    I use sliding axle trailers often and you can do the same kind of tricks with them. For instance, using the Landoll hitch hydraulics I picked the rear end of the semi up in the air, locked the trailer brakes and used the power rear axle slide to pull the truck's rear axles over a 6' wide ditch.
    Every time I have tried to put 50K+ pounds on one axle like they do in that video I have airbags explode. The rigs they are using to do that must not have any suspension at all to squish the tires like that and not fail.
