Moving a lathe in a pickup truck
Page 1 of 3 123 LastLast
Results 1 to 20 of 59
    Aug 2004
    Virginia
    2,467
    179
    980
    Default Moving a lathe in a pickup truck
    Good evening. I picked up a Monarch EE for my son for Christmas and I was hoping someone could tell me if it would be safe to move it in the back of my Ford F-250. It's only a 30" lathe but I don't know exactly how much it weighs. I have hauled a whole pallet of Quickrete and nothing broke so I think it will be okay but I would like a second opinion. Thanks very much.
    Aug 2014
    Hoboken NJ
    88
    15
    We did the same thing with a 14". We just used 2" ratchet type ty-downs. I remember joking that the guy behind us will never know what hit him.
    Nov 2019
    Kentucky
    28
    8
    7
    I just moved a LeBlond Regal 15x30 and I would say the biggest hassle would be getting it lifted into and out of the truck. If you have the equipment available to lift it and the heavy end is up close to the cab then go for it. Other wise I would try and find a trailer with a very sturdy ramp, pallet jack, some type of winch or come-along, and a dolly for the light end with plenty of cribbing, pry bars, and a iron digger.lathe.jpglathe.jpglathe.jpg
    Jul 2009
    Peoria, IL
    11,738
    51
    9007
    Should be fine. Just tie down well.
    Aug 2012
    California, Central Coast
    4,409
    2284
    1759
    I just moved a Nebel 1308 which I read here is heavier than a 10EE on my F250 with no issues at all. Headstock to the cab.
    Oct 2009
    Louisville, KY, USA
    996
    214
    219
    Make sure your tie downs are attached to frame members and not just the sheet metal bed.
  7. Likes tc429 liked this post
    Aug 2006
    Virginia
    618
    885
    357
    Quote Originally Posted by fciron View Post
    Especially if the truck bed is the highly respected “ military grade aluminum “!
    Joe
  9. Likes Rudd liked this post
  10. #8
    Jun 2008
    Bellingham, WA
    4,120
    992
    2261
    I am pretty sure mine weighed 3500 pounds. Do make sure you bolt it to at least 4X4 sleepers as wide as will fit into your truck bed as this lathe, like most, is very top heavy. Toppling it and breaking hard to replace wheels and levers (or worse) would make for a bad day. There are two hoist point threaded sockets in the bed near the head stock intended for lifting eyes. They may be covered over with paint. Sliding the tailstock to and fro can tune the lift balance.
    That is a pretty nice Christmas present!
    Denis
  11. Likes macds, tc429 liked this post
  12. #9
    Aug 2015
    Illinois
    1,500
    1107
    646
    If you can rent a drop deck trailer it makes the job a lot easier.
  13. #10
    Aug 2014
    Hoboken NJ
    88
    15
    Then there is the easy way to move a lathe. Hire a car carrier. They can slant their bed any way they want and they have a winch. The guy will set it right were you want it for a reasonable price. Beats you fucking up your back and then some.3500 to 4500 pounds of steel can screw you up good if it gets away from you. This is now how we move all our equipment these days. Bob L
  14. Likes Pathogen liked this post
  15. #11
    Oct 2009
    Olympia, Wa
    672
    309
    197
    That's a lot of focused weight in a 3/4 ton. If it was 10 miles away it might be do-able, but 150 miles away I would rent a trailer. And I'd still prob try to rent a trailer if I could easily find one.
  16. #12
    Oct 2008
    Central Ohio, USA
    1,965
    847
    568
    Rent a tilt trailer, life will be so much easier.
  17. Likes Dan from Oakland liked this post
  18. #13
    Jul 2004
    Houston, TX USA
    30,870
    Ignorant me moved a ancient Hendey maybe 30 years back in a light Chevy (whatever the little four banger pickups were called). Probably about 1000 lbs of tall iron
    Flipped over and out on a slow turn, and then we were dragging it along upside down nestled up against the poor embarrassed Chevy
    It was a real educational event
    The buyer had to come along with his strapping young brothers to take care of the mess - they all thought it was perfectly normal
  19. #14
    Sep 2006
    SE PA, Philly
    5,517
    1071
    1977
    IIRC, the 3500 lb weight mentioned above is correct. An F-250 has a rated payload of about that much:
    What Is the Maximum Payload of a Ford F-250? | Reference.com
    Definitely a strong pallet or sleeper arrangment, with all the cautions about top heavy.
    The one think I'd worry about, whether in the bed or on a trailer, is getting the thing into oscillations. Nearly did that with a small (12" delta) wood lathe. Well, it was small for a 1960 Delta, probably 1500 lbs. So go very slow, and even slower when you turn.
    The truck weighs about 5800 lbs, and the lathe about 3500. And you're putting the CG of the lathe about 5 foot higher than the axle. Which is why a lot of folks would prefer the trailer approach.
  20. Likes Ziggy2 liked this post
  21. #15
    Mar 2017
    233
    104
    Dear Crossthread,
    Will you adopt me?
    A Schaublin 70 with the dividing head and milling setup would make a great stocking stuffer.
  22. Likes digger doug liked this post
  23. #16
    Sep 2002
    People's Republic
    4,455
    433
    2706
    IIRC the EE weighs the better part of 3000 pounds.
    The issue is tipping sideways, vaulting out of the bed and onto the volkswagen beside you
    Have it bolted to a pallet the better part of the width of the bed, securely.
    Strap it down till you are afraid for the truck
    I borrowed my friends 73 chevy half ton to bring home a short table short knee bridgeport[1500 pounds] I don't recall it being on a pallet and we used some real industrial ratchet straps to hold it down. All was fine, going up my steep rocky driveway elicited some butt puckeringly ominous thunk thunks, but it stayed in the truck. That was 35 years ago, and I don't think I would do that again.
    A pair of 4 foot 4x4 and some large lags, and more than 4+ real ratchet straps and I would probably be confident
  24. #17
    Jan 2012
    Midland, Texas
    1,563
    565
    800
    Secure the upper parts of the lathe securely to each side of your trailer. Each strap should attach to the lathe separately. In the photos above, the top of the lathe is NOT secured. There is a strap going over it, but nothing to prevent the lathe from sliding under the strap and tipping over. I would use 4 straps and secure them to the spindle, headstock, tail stock, or bed individually. Be sure to angle the straps toward the front and rear to prevent fore/aft movement.
    Drive slow, take lightly traveled routes, watch for potholes!
  25. Likes Bobw, tdmidget, tc429 liked this post
  26. #18
    Dec 2016
    Wisconsin
    102
    19
    I moved my South bend Nordic in the back of my 97’ Chevy 3500 with a service body. No issues.
    Moved a 4 foot 2500lbs press brake in the back of my padres 08’ Chevy 2500 from Chicago to Milwaukee. No issues.
    I did have a issue moving my Cincinnati tool and cutter grinder in my truck. It broke the pallet and ended up leaning on the compartment. I highly advise against a pallet. I always keep some cribbing around for moving equipment. I would bolt some 4x4’s or 2x4’s to it and lay a few sheets of plywood in the box to save the tin truck box floor. I have a stack of plywood sheets I save for that reason. Even use it on trailers so I don’t tear up the decks if I have to slide a machine across.
  27. #19
    Apr 2007
    mays landing NJ
    531
    469
    147
    A friend asked me to help him pick up and deliver to his shop an older lathe he got cheap. I asked him about the lathe and all he knew that it was running and all parts were in good shape. We drive over in my F-150 and I asked him if he was nuts. The lathe was an American Pace Maker, probably weighed 8000/9000 lbs. I told him to hire a rigging outfit. The owner looked at my truck and said " you ain't loading the lathe on that toy truck sonny.
    The seller delivered the lathe for a $1000.00, lathe probably was worth it if my friend knew how to run it. I was not there when it was delivered but am told it went smoothly.
  28. #20
    May 2014
    Massachusetts
    130
    8
    34
    Quote Originally Posted by Joe Rogers View Post
    Joe
    He said F-250, not their 1/2 ton toy pick-up model.
