My sweet little Hyster 60
Likes Likes:  0
Results 1 to 12 of 12
    Apr 2020
    Oregon
    Default My sweet little Hyster 60
    Hi Folks,
    I own a Hyster 60 which needs a water pump. Unfortunately, I cannot figure out which motor it has in it. The valve cover says P N 1484444. I'm needin a water pump. Where should I start looking?
    Bill
    Dec 2012
    AUSTRALIA
    2,833
    12
    916
    If its a flathead ,it will be a Continental F160 ?....I used to get all Continental parts over the counter from Hyster....the water pump was a unit bearing type ,easily fixed with bearing shop bits .
    Nov 2008
    Madera county california usa
    2,530
    21
    639
    Take the pump off and get it rebuilt.
    Many places still perform this, about $100.00...
    Apr 2020
    Oregon
    Thanks Guys,
    The engine is an overhead valve, four cylinder affair. I believe it's a 1995 model. I had hoped to have the new pump on hand when I tear into it.
    Bill
    Sep 2003
    Etters Pa USA
    1,113
    30
    Quote Originally Posted by KZQ View Post
    Thanks Guys,
    Bill
    It most likely is the GM engine but I forgot the series,but that should get someone else's brain in gear? Sorry about that!
    Jan 2017
    Oregon
    3,477
    715
    2421
    Probably a Mazda 2.2l, but since the OP is keeping the year and model a secret who knows? There were several different engines used in 6K Hysters.
    Call Hyster, give them the year and serial number. Get the correct part number and buy a new pump on ebay.
    2028644, 901579801 WATER PUMP FOR MAZDA F2 2.2L HYSTER + YALE FORKLIFTS | eBay
    Mar 2011
    ohio
    60
    12
    10
    best answer right here. Call the company direct and have them help you identify it, then you can look for less, or have the needed information to call and request a rebuild .
    Feb 2004
    New Jersey
    43
    10
    Google 1484444 says it's a 3.0 Vortec.
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,147
    450
    1077
    Quote Originally Posted by imported_Jim_P View Post
    Thats a pretty common GM marine and "off road" engine.
    If you google "GM 3.0 waterpump" and look at the images, if that matches the image of your existing waterpump you're probably good to go.
    Imo its unlikely that Hyster did anything to the engine other than put on a propane carb and bolt it into their powertrain/transmission.
    Jan 2017
    Oregon
    3,477
    715
    2421
    The Mazda engines were overhead cams, the GM is a pushrod engine. Should be easy to tell.
  11. #11
    Apr 2020
    Oregon
    Thank Guys,
    It's a push rod motor so I guess that makes it a GM.
    I have another problem. There is some sort of propane warming device, I think that's what it does, It continually whistles. When I depress the brass push button the whistle stops, as does the engine. Where can I learn more about this whistling fuel heater thing?
    Thanks in Advance
    Bill
    Later:
    OK the whistle is coming from the regulator. I'm going to run it until the engine's up to temp and see if it stops. The regulator is wet with condensation not quite frost yet.
    Bill
  12. #12
    Jan 2017
    Oregon
    3,477
    715
    2421
    The regulator/vaporizer should not whistle or ice up- that sounds like a possible leaky diaphram.
    The button is a primer button. Don't give it more than a second- it shouldn't be necessary at all.
    I'd replace it or put a kit in, they aren't expensive and you don't want any LPG leaks...
    Google IMPCO Model J, pretty common on Hysters.
