Need help id'ing a Clark C30050 mast cylinder
Tim S
Mar 31, 2010
Kernersville NC
I have a Clark
C30050
356 555 1528 9 86
side shift
4100 lb cap
I'm trying to find a seal kit for the mast cylinder. I have looked all over the uprights trying to find the model. The only thing I can find is a spot where a tag was probably welded to the right upright. I cannot find any stamped numbers.
Is there any id on the cylinder itself?
Or other options?
Solidliftparts.com was able to source me the correct seals for my 60 year old forklift. I think it was $8 shipped for the shaft seal.
If you email them the serial number they will tell you exactly what mast you have.
Any good hydraulic shop should be able to get you some seals. You'll just have to tear the cylinder down to get the seal measurements.
Even if you could find the mast number, there is a decent chance that Clark has discontinued that part, and if they do have it, it will be insanely expensive.
All good points thanks. Solidlift is working on it. Irregardless we're tearing it down.
I forgot about Hercules, if i recall correctly they have excellent service.
