Hello everyone,
Iam from the Netherlands and i bought a old Towmotor forklift, the type plate says : model 510PG2524 Type G Truck
It runs and drives, only problem is that the waterpump is leaking.
That will be a small fix, i figured out that this forklift have a continental F163 Engine and i can buy the waterpump parts locally.
I have another queston,i have 2 pedals on the floor, 1 clutch and 1 brake.
there is a handle onder the steering wheel with''neutral, forward an reverse position.
When i push the clutch nothing will happen, i see there is a linkage with the brake and when i push the cluch the forklift brakes and stops.
I opened the clutch box (big plate in the floor behind the steering wheel) I see there 2 gears, big one and a smaller one and a clutch disc with fingers.
All the fingers are ok and no one broken.The whole box is filled with oil (not full, its below the cluch dic)
When i push the cluch i see nothing moving in the clutch box, only a plunger (hydraulic valve ??)in the front of the gearbox moves in and out.
Can anyone explain how this transmission works ? And is there an oil level and where can i proove it ?
And is there something on this gearbox that is can set ? As i told, the forklift drives forward and backwards, but when i loose the clutc/brake it jumps forwards or backwards (even the position the lever behind the steering wheel is)
Also the hydraulic steerign didnt work wel but thats for later.
