Hello all
I am in need of some help here. I have an older Yale model #L83F100SBS083, serial #P378430. It has a slant 6 Chrysler and is a propane model. I am having a wiring issue , its dead, my guy running it says it seems like it ran out of propane, changed bottle but that wasn't the problem. After that it wouldn't crank and can jump the starter and it works. Then noticed the wiring block under the dash was melted. We removed the block jumpered wires together still nothing . Looking for a wiring diagram or maintenance manual . I called the nearest Yale equipment dealer and was told its to old that they wont have any info on it and that they would have to call the factory. Still don't know the age , not that it really matters but just curious. Its weight is a little over 14,000 and its right in the middle of the shop floor. The fuses are good, wondering if there's a diffusible link somewhere hidden . Any help in this matter will be greatly appreciated. Thanks in advance for any ideas or wiring diagram or maybe even a maintenance manual. Mike
