Nissan H20 rear main seal alternative?
Results 1 to 8 of 8
    Feb 2006
    Republic of Texas
    2,452
    Default Nissan H20 rear main seal alternative?
    Nissan H20 engine. Is there an alternative for the rope rear main seal?
    Aug 2012
    California, Central Coast
    3,327
    2153
    1295
    Take the measurements to your local bearing and hydraulic store.
    Aug 2010
    Minnesota
    1,984
    150
    1464
    Not seeing one commonly available... if you have the tools at your disposal I'm sure you could make one with little trouble. Find a seal with the proper ID and them making something to hold it and a way to bolt that holder to the motor.
    Jun 2013
    Northern Il
    1,277
    671
    1210
    Not that I am a fan of the old rope seals but they did work quite well when installed properly considering the technology.
    I think that making a modern lip seal work for your application would be more problematic than you realize.
    It would require machining the block to have any chance of success. Too much effort for what you would gain.
  5. Likes motion guru, Garwood liked this post
    Dec 2012
    AUSTRALIA
    1,889
    9
    580
    Most of these engines went from rope seals to a palm seal around the crank flywheel flange........remember the rope seals were asbestos,a great material because it didnt cut shafts.......any kind of plastic lip seal will surely cut the shaft.........this is why most engines now have a seal and wear ring combined...................if a rope seal leaks,there is a good chance the rear main is worn excessively.
    Jul 2009
    Peoria, IL
    11,697
    50
    8949
    I think Ox maybe had a thread about converting an engine to a lip seal by machining the OD of the flywheel flange. I can't seem to find it.
    Dec 2012
    AUSTRALIA
    1,889
    9
    580
    Engines with a lip seal generally have a much wider flange on the crank...... ,a flywheel housing will need to be cut away to take the seal housing,or modified to have a integral seal mounting.....the 3208 caterpillar is like this.........but it means the seal must be mounted after the housing is installed and carefully aligned.IIRC,the Dodge SV 6 had a rear lip seal in two halves secured to the block with screws.......Mack used a lead wire in a groove as a seal for many years.
  9. #8
    Jul 2019
    Connecticut
    13
    Quote Originally Posted by alphonso View Post
    Keep adding oil? Sorry, couldn't resist.
    I've rebuilt many an engine with rope seals. The best thing to do is to pack as much rope into the groove as you can. carefully use a punch to keep pushing it in the top groove, then pack into the main bearing cap, but make sure it doesn't get between the cap & block or you'll have a knock.
    Good luck,
    Ted
