jermfab
Cast Iron
- Jul 25, 2013
- atlanta, ga
So I chimed in a couple times on the powerstroke thread. I was honest there and will start here the very same.
I’m neither a Ford guy or a diesel guy. My girlfriend has horses and a horse trailer. She bought a 97 F350, fleet model, 2WD diesel with an automatic a while back to tow with. I was driving it yesterday and got hit. Hard. Surprisingly hard in the worst place possible:
From an insurance standpoint I’m certain both vehicles would be totaled. Biggest difference was that mine drove off while the Hyundai left on a wrecker, most likely headed for scrap. All the same, despite driving off under its own power the F350 isn’t really drivable.
There’s no need even thinking about an insurance claim on our part as the insurance isn’t there and wouldn’t help if it was. We couldn’t replace the truck, right now, for what the totaled value from insurance would be. The truck only has 120k mile. It runs good, shifts good and handles/stops as well as it ever will. It’s not totaled because it’s worth fixing. That said, I’m convinced that “fixing” is gonna mean a new cab.
Despite my worst nightmare of getting in a bad accident in a borrowed vehicle, serendipity was shining on me yesterday. Less than an hour before the crash happened, this truck became available to me at a pretty good deal:
It was too good to pass up at $3500. 140k miles, 4WD, 5-speed 3/4-ton. With the gas big block 460.
I don’t know Fords... I do know they took the opposite approach to GM and tended to put a different transmission behind each of their engines.
The girlfriend is taking things well enough so far. I’ve told her the brown 250 is hers until I can get the white 350 fixed. Most importantly, at least she can take the horse and trailer when need be. I’m pretty sure I can find a cab for the white truck. I don’t WANT to, but it’s within my means to swap the cab. Of second most importance to my girlfriend is having a diesel engine. She’s SOLD on the 7.3L mystique. She doesn’t need 4WD and isn’t very comfortable shifting, but towing the horses with her girlfriends is the most important thing.
So...
To the Ford guys out there:
Will the 7.3L mate to the 460 trans? She would LOVE the brown truck... if it was a diesel. If so I figure it’s about the same amount of work as swapping the cab on her white truck.
As I have the entire diesel truck sitting there, that is my easiest option and I think Megan will be cool with it. I may have to spend a bit more and paint it white for her.
Otherwise it’ll be swapping the cab on the white truck and probably making it a flatbed with the E350 school bus axle I scored at work the other day. With the acquisition of that axle I had finally convinced her to let me build a flatbed... and then was at the wheel when her truck got hit.
Another question for the Ford guys:
How different are the chassis mounts for different cab layouts? Girlfriend doesn’t want a single cab, but would have no issue with a 4-door cab. I’m assuming the front cab mounts are all the same and I’ll likely just have to fab two or four mounts to go from extended cab to crew cab... but I would love it if someone out there that knows these trucks better could confirm.
Anyhow. I could use some advice.
I tend to appreciate, and typically respect, the judgment of this forum. Even when it gets mean-spirited. Do your worst. I can log off here, no matter how well she’s taking it, eventually I’ll get worse than this crowd can hope to give unless the girlfriend gets her diesel-powered big girl truck back.
Be safe
Jeremy
So...
Be safe
Jeremy
