Pallet jack...how much labor and/or PITA factor is there in installing new seals ?
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Dec 2000
    South Carolina
    51,807
    3216
    6061
    Default Pallet jack...how much labor and/or PITA factor is there in installing new seals ?
    Multiton TM55... manual pallet jack... after 15 years of use without leaking a drop, I install all new wheels and the next day it starts leaking like crazy
    New seal kit about 45 bucks, but I'm in no mood to install them if it takes more than an hour or two....temped just to chuck it and buy a new jack...except after paying money for new wheels that thought gives me pause. What say ye ?
  2. Likes JoeE. liked this post
  3. #2
    Virginia
    22,138
    7561
    12725
    Quote Originally Posted by Milacron View Post
    Should have unbolted the old wheels instead of leaving it in a fire overnight to burn them off?
    Or did you just have it downside-up long enough to encourage some of the hydraulic oil to find a way out?
    A Multiton would easily rate a new seal kit in my book.
    Another 15 years again next round off new ones? Even half that, it would no longer be MY problem.
    Nov 2013
    Eastern Massachusetts, USA
    7,819
    6493
    6918
    It would take more than an hour because the best way to install new seals is to compress them with a ring compressor or strip of metal plus hose clamps and then place it in a freezer. Then when you take it out you quickly remove the band(s) and slide it into the lubricated cylinder. The rest would probably take up to an hour but well worth doing, especially after springing for new wheels.
    Virginia
    22,138
    7561
    12725
    Quote Originally Posted by Scottl View Post
    WTF?
    A Multiton / Jungheinrich PJ is a simple critter. It don' need no cryogenic-fu.
    Multiton Pallet Jack Parts | TM,M,J & S | Helmar Parts
    Read the text. Braking issues symptom. "Quick repairs".
    Not as if it was a cat-shot launching bombers off a carrier deck.
    Nov 2013
    7,819
    6493
    6918
    WTF?
    How many lift cylinders have you actually done?
    Some have built-in tapers that make assembling with new seals easy but others can be a real bitch to reassemble unless the seals are compressed. I've done both types, and am perpetually grateful to the old timer who taught me that freezer trick.
    Mar 2009
    Eureka, CA
    4,454
    1067
    1816
    HUH...I've rebuilt a bazillion hydraulic and pneumatic cylinders of all sizes and shapes and have never needed the assistance of my Whirlpool reefer.
    To me, it's too coincidental that the pallet jack started leaking immediately after working on the wheels. Before I went further, I would park it somewhere for a few days to see if the mysterious leaking 'self healed'.
    Stuart
  8. Likes Screwmachine, sealark37 liked this post
  9. #7
    Dec 2000
    South Carolina
    51,807
    3216
    6061
    Quote Originally Posted by atomarc View Post
    There's no way the new wheel install directly resulted in the leak (wheel replacement involved lifting the jack ends perhaps 1/4" with toe jack...no seized parts, no hammering..easy peasy)
    But thinking back on it, the new wheels allowed me to actually use the jack later that day and I vaguely remember maxing it out capacity wise....although I didn't notice anything amiss at the time, I suspect I blew a seal during the lifting...
    In this case the leak does not go away... at least not until the fluid runs out...quite a puddle.
  10. Likes JoeE. liked this post
  11. #8
    Mar 2009
    Eureka, CA
    4,454
    1067
    1816
    Not being a pallet jack technician, this is all assumption, but even the lowest tech hydraulic lifting device would have an internal pressure bypass to prevent killing said device when overloaded. Just like a hydraulic jack has. The relief valve should be internal and show no external leakage when overloaded...maybe this pallet jack vents its overload to the outside to notify the user he has exceeded the limit. Not likely, but it is a thought none the less.
    Stuart
  12. #9
    Sep 2005
    Oakland, CA
    3,130
    675
    1030
    Ours never puked any oil- just simply stopped lifting. Changing the seal was amazingly easy and quick.
    I recall its a 5K Crown. A buddy took theirs to a hydraulic shop and paid $125.00 to have the seal changed.
  13. #10
    Aug 2006
    Kansas
    2,346
    18130
    1044
    ... have no advice, just a little heads up to our frugal members: even inoperative manual pallet jacks are good for storing heavy items on to ease moving them around the shop. I had bought an 50's era N.O.S. Pexto sheet metal slip roll at an auction. The kind that's built on a steel cabinet of sorts. I mounted it on a junk pallet jack. That allows me to roll it out in the open to roll things, then roll it back under the pallet rack where it lives... easily maneuvered mounted like it is. I've bought 3 inop pallet jacks at auctions just for that purpose.
  14. #11
    Virginia
    22,138
    7561
    12725
    Quote Originally Posted by JoeE. View Post
    Keerful.
    One lad got into a spot of trouble with a wife over such accumulated discards.
    Seems she was cross because the house was always littered with empty whisky bottles.
    He was puzzled as to why she was pissed at HIM?.
    Said he was absolutely CERTAIN he had never brought home an empty whiskey bottle in his entire life.
  15. Likes Glock34 liked this post
  16. #12
    Sep 2016
    Missouri
    1,240
    1024
    418
    Keerful.
    She shouldn't be worried about the empty bottles . At that point he's on the downhill slide and maybe she needs to work on how to empty the house of him.
    Back to the pallet jack , it's former dependability world steer me toward repair.
    Joe's suggestion of repurposing is not bad if it fits a need.
  17. #13
    Virginia
    22,138
    7561
    12725
    Quote Originally Posted by mllud22 View Post
    LOL! "So called "servile" (they are no such thing- it's an act) Japanese wives even have a term for it. Translates to "Big Garbage".
    Absolutely! The ones acquired as "junk" as well. Not as if they were Wasp Major aircraft engines.
  18. #14
    Dec 2000
    South Carolina
    51,807
    3216
    6061
    FWIW, it works fine and will still raise an inch or so then runs out of oil. This is the "narrow" version with 20 inch width, 48" forks, 5000 capacity. Except for seals, in great condition, forks not spread or bent, decent paint....Someone give me 75 bucks for it.
  19. Likes JoeE. liked this post
  20. #15
    Dec 2015
    Illinois
    687
    230
    411
    If you can drop it off in central IL I could be your guy.
  21. Likes JoeE. liked this post
  22. #16
    Virginia
    22,138
    7561
    12725
    Great price. Nice country for a visit. But too long a drive. Too hot a time of year!
    Only one I'd want is that special shorty-forky Pallet Jack you got that we used to spin that French Gal 90-degrees whilst already *inside* the Penske box in no SPACE!
    PITA UNdoing that with skates and chains to be able to fork it when I unloaded.
  23. #17
    Apr 2004
    Modesto, CA USA
    8,942
    1773
    I guess you are not aware that rubber expands when it cools. Cooling it make sit bigger and harder to force into a bore. Warming it up will shrink it a little and make it easier to insert into a bore.
    Bill D
  24. Likes JoeE. liked this post
  25. #18
    Feb 2011
    3,060
    2904
    1458
    I'm not familiar with that particular jack, but we've rebuilt several. If you have the kit and tools, they come together without too much trouble.
    The most trouble I ever had rebuilding pallet jacks was years ago when we had a couple to do and I delegated them to someone else. One was a no-name import that I wasn't able to find a kit for so I told him his scrapper brother could take it away. The other was an old foot pedal Multiton. I gave him the kit and went to do something else. I came back later and tried to use it and it still was creeping down under load. It was obvious that it had been taken apart and I looked at the kit on the table, half the parts in the torn bag looked new. I asked him about it and he got quiet scratching his head and said he couldn't remember if he changed the parts.... Later that week after his scrapper brother had taken a load of junk away, I see the POS import pallet jack sitting there and the Multiton gone. Once again, he's quiet, scratching his head.... He doesn't work here anymore.
  26. Likes mllud22, neanderthal mach liked this post
  27. #19
    Virginia
    22,138
    7561
    12725
    Quote Originally Posted by Bill D View Post
    Bill D
    LOL!
    Yeah. Did have me scratching my head why we used warm hydraulic fluid, glycerine, or just sioapy-water on elastomeric AKA "rubber" goods ...
    ... when we had a PAIR of one-TON per 24 hour day Liquid Oxygen / Liquid Nitrogen plants chunking away and a metal pail of "crude LOX" at over 280 F below zero was a simple valve-twist away!
    Human nature.
    Some "shortcuts" are actually just time-wasting "detours" to make simple things
    complicated?
    "Crude LOX" was sure hard on snakes, though!
  28. #20
    Aug 2012
    Lower Thumb, Michigan
    285
    74
    205
    ....aaaand what's the problem with hoarding Wasp Major aircraft engines?
    Mike
