In this case, one 8,000 lb capacity Hyster LP cushion tire with 5 foot forks that can actually pick up 9,500 lbs due to added counterweight (always attached) and one Daewoo 5000 lb electric cushion tire with 5 foot forks but probably only good for 4,500 lbs due to slightly smaller than standard battery size. (i.e. not as much counterweight as normal)
The idea would be demand drill loaded either at back of trailer or nothing else behind it when delivered and to drag the radial drill to edge of semi trailer, then get both forklifts close together snuggled all the way up to the base, both forklifts pick it up together, semi drives out from under, both forklifts lower it to machinery skates on ground for pushing it into the shop on skates. (or pulling with electric pallet jack)
Radial drill base is 40 inches wide (and 8+ feet long) so at least we would be closer than 24 inch capacity ratings, for a little more capacity. In fact because of that, I suspect the Hyster would pick up a radial drill with the same base width that weighed 10,000 lbs by itself...but 12,100 would be unlikely to happen.
I heard of this being done before but sounds pretty hairy with a 9 foot tall radial drill. OTOH would be on single drop trailer so not too high up to begin with. And yes of course the arm/head would be absolutely locked in place via steel strapping in addition to it's normal hydraulic locks since any arm swing could be a disaster. And there would be the usual thin plywood strips between forks and machine base to inhibit slippage.
I did load a huge VMC via 2 forklifts once but that was different in that the VMC was nearly as deep as the trailer so each forklift was on the opposite side of the trailer and if one got a little lower or higher than the other it didn't matter so much (further fun added by it happening during a light snowstorm) I would think in this case the two forklifts need to be in near perfect sync, which would be harder to do.
Thoughts ?
Thoughts ?
