Pintle hitch ok towing with typical SUV ?
Results 1 to 4 of 4
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,284
    2785
    5589
    Default Pintle hitch ok towing with typical SUV ?
    Have used pintle hitch trailers, towing with Ram 3500 diesel dually, and had no issues at all...nearly as smooth as ball connection. But with typical 7K tow capacity SUV and obviously softer suspension than a one ton truck, there I wonder if there might be too much clanging around ?
    Aug 2012
    California, Central Coast
    3,329
    2153
    1296
    Probably not a problem with some tongue weight,
    Virginia
    26,094
    7561
    8230
    Quote Originally Posted by Milacron View Post
    Have used pintle hitch trailers, towing with Ram 3500 diesel dually, and had no issues at all...nearly as smooth as ball connection. But with typical 7K capacity SUV and obviously softer suspension than a one ton truck, there I wonder if there might be too much clanging around ?
    Wasn't an issue with a measly quarter-ton M-151 "Ford Jeep", trailer empty or loaded to triple the Jeep's mass, laterite roads or off-road. So no, I'd not give it a second thought.
    So long as all players are of reliable quality, it is a safer and stronger system with more tolerance for extreme excursion (still stays coupled, even if trailer has gone clear upside-down!) than a ball, anyway.
    If the "clanging" was a serious issue, lunette or pintle would show extreme wear. Mostly, they show near-zero wear, relative to their tolerance for it.
    Nov 2007
    marysville ohio
    9,261
    2643
    6121
    It will be fine, towed with a pintle on the wifes Tahoe, Grandkids in back watching the video. No problems at all.
  5. Likes Milacron liked this post
