CutterComp
- Jul 5, 2019
I have the opportunity to obtain a Clausing 5914 for free, I just need to go get it. The scenario is an estate cleanout; I'm good friends with the sister of the man who owned it. He rented space in a factory and had the lathe there. Now that he has passed on, the factory wants it gone ASAP. The family said I can have it if I can move it.
I had the chance to look at it months ago. It seems to have only had light use, the vari-speed drive seems to work correctly and isn't too loud, although I noted the resevoir was empty. The ways seem to have little wear. Mind you, I wasn't investigating it too closely because this was before I knew I had a good chance of getting it. And unfortunately, it's an hour and a half away from here and access to the premises is difficult. Hence, I'm coming here with a few questions for other Clausing 5914 owners.
I'm planning to make a wooden frame on which to bolt the lathe. Basically, 4x4s running perpendicular to the bed that will be through bolted to the machine feet. I will also take 2x4s running parallel to the bed and lag them to the topside of the 4x4s as stabilizers. Heavy duty casters will be bolted to the underside of the 4x4s at all four corners. I will lift one end of the lathe at a time with an engine hoist to install the 4x4s/casters. My thought is to widen the footprint of the lathe to give it more stability because I know they're top heavy and weigh roughly 1600lbs. From there, I hope to roll it out of the building which involves a long ramp, a step over the door threshold, and a small step down onto the pavement. Then use a winch to pull it up the trailer ramps onto a car trailer and strap it down.
Questions:
1) Can someone give me an accurate measurement of the center to center distance between the two headstock feet (measured perpendicular to the bed)? And the same measurement for the two tailstock feet?
2) A measurement of the distance between the headstock and tailstock feet. I will need to have the lumber precut.
3) Do the leveling screws thread right out of the feet? What diameter are they? Need to know what size bolts I can use to bolt through the feet.
4) Other advice on moving this? Getting it onto the trailer with ramps, a winch, and engine hoist? No forklift will be available for loading. Pictures of how you moved yours would be great.
5) I know there was a Yahoo Group for Clausing Lathes but now Yahoo Groups is dead. Did that group move elsewhere? I want to be able to use that resource.
Thanks!
Questions:
Thanks!
