Rigger recommendation in queens NY?
Likes Likes:  0
Results 1 to 7 of 7
    Sep 2017
    New Jersey
    123
    29
    Default Rigger recommendation in queens NY?
    Hi,
    I have a Van Norman 12 mill (1800lbs or so) waiting for me in an old factory in queens, NY, but it will require an insured rigger to get it out.
    Anyone have a good, reasonably priced rigger nearby?
    I've talked to Pedowitz already, they are willing but twice the price of the machine to move. The place is not ground level, has a loading dock, uneven wood floors, no pallet jacks or forklifts, so not as easy as rolling the machines on pipes to a door and winching onto a car wrecker truck.
    Thanks!
    Phil
    May 2011
    New Jersey
    1,920
    173
    1042
    You could try hopatcong rigging in Sparta nj
    Apr 2005
    Beaverdam, Virginia
    7,240
    603
    3392
    I would think with the cost of property in that area and the worst traffic in the USA riggers are probably going to be expensive.
    Jan 2004
    Halifax Nova Scotia
    1,771
    249
    I have not seen the site but it might be as easy as rolling it to the door and loading on a roll back tow truck. For the uneven wood floor get several stripe of 1/8 steel a couple inches wide . Lay then on the floor and roll the machine on the path made by the steel. Use 4 pieces and you can relay your tack as far as you want to go. Most roll back tow trucks also have a wheel lift stinger on the back so they can carry one car and tow a second. The wheel lift stinger can also be used to raise the rear of the truck so it can be raised to the height of a loading dock. I have used roll backs at loading docks many times to move machine tools and they ideal for the job because they can match the dock height exactly
    Sep 2017
    New Jersey
    123
    29
    Quote Originally Posted by Frederick Harvie View Post
    Hi,
    Thanks. I hadn't considered the rollback truck platform would be high enough to match the loading dock height, but that makes sense and could be easier. I've moved my bridgeport and surface grinder that way but never from a loading dock.
    Thanks!
    -Phil
    Feb 2006
    so cal, usa
    581
    201
    141
    Used to use a rigger in the Bronx called the Hulk. Donno if he's still there or not. He was a good guy.
    Apr 2011
    New York
    283
    201
    149
    Bruce Preiser, in Brewster, MIGHT go into the city. Fourth generation rigger, has all the old and new toys to just about any job.
    Crane Rental - Based in White Plains, Carmel - Preiser Rigging & Crane Service Inc
    best of luck
