Show me your...Shop Truck? - Page 4
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 83
  1. #61
    Mar 2009
    Eureka, CA
    3,904
    813
    1411
    Yes, it drew through the carburetor then pushed into another part of the adapter and into the engine. It was a early 'Turbo-sonic' unit and it worked pretty well. Had a 7 lb spring in the wastegate.
    Stuart
    PS. Remembering, as it has been a long time ago, the adapter the carb sat on had a series of 4 floating steel discs in it. Under normal running the fuel/air would enter the engine through these ports. Under boost, the positive pressure would close the discs and the fuel/air would now be pulled into the turbo and sent to the engine below the adapter. It sounds sort of funky but it did work and there was no noticeable lag as it went from no boost to boost.
  2. Likes kustomizer liked this post
  3. #62
    Nov 2007
    marysville ohio
    9,798
    2809
    6491
    Quote Originally Posted by atomarc View Post
    Stuart
    Did it have anything to richen the mixture when it was on boost or did it just rely on airflow through the carb?
  4. #63
    Mar 2009
    Eureka, CA
    3,904
    813
    1411
    Keep in mind this was a bazillion years ago I have have cerebral cobwebs now. It was a Rochester Quadrajet and the secondary metering rods and jets were modified to dump extra fuel when they opened..when the motor was under boost. At least that's how I remember it. This was in the mid to late 70's and things were still somewhat in their early stages, turbo wise..at least in my area.
    So, nothing special to richen the mixture, only tweaking in the carburetor.
    Stuart
  5. #64
    Aug 2007
    GA
    809
    140
    Lift-a-load, Megahoist, isuzu FTR. I like those NPRs but they have a narrower track than a dually and are not dock height...
    Attached Thumbnails Attached Thumbnails img_20190913_0958159.jpg   20140922_143551.jpg   004-4-.jpg   024-2-.jpg
  6. Likes johfoster liked this post
  7. #65
    Dec 2016
    Arizona
    234
    109
    134
    I was trying to buy an FTR for awhile last year. I would still get one, but the NPR is just much more readily available and cheap on the used market. I never need dock height so it is nice having the lower bed. I would probably still get an FTR if a deal came up just to have a heavy flatbed for hauling equipment etc.
  8. #66
    Aug 2007
    GA
    809
    140
    I really like my FTR, this one used to be a reefer, Allison 3000, built to 33k specs but tagged at 29590, but it is pretty heavy, and only gets about 9 mpg average. Its a tool though and works perfectly for what I need it to do. I built a mini sleeper in the back that I haven't had to use yet, but it's comfortable. Cabover is great bc the overall length is so short, very manuverable.
  9. #67
    Dec 2016
    Arizona
    234
    109
    134
    I am curious to see the sleeper set up if you care to share that. I have always imagined doing something similar if I get a bigger truck for buying equipment and such..
    I bet the FTR still turns better than my Chevy 3500 in the first post even though it is such a large truck. The tight radius and fitting in a regular parking spot width are both things I really like about the NPR.
  10. #68
    Aug 2007
    GA
    809
    140
    I just built a birch ply box perimeter frame so I could have storage underneath, split hinged lid so I can open it from either side if I push whatever is on top to the opposite side. It doesn't have a bottom, just meets the stock floor profile around the edges. Thermarest self inflating camping mattress fits perfectly. I have translucent corregated plastic panels (like real estate sign material) that pop in to the window trim- lets light in but you can't see in, and an LED goose neck reading light. Truck comes with a curtain track in the roof, so I hung a sliding curtain in there that runs just behind the seats. Tight, but fine for me. photo is before I added the curtain. Would not qualify as a sleeper by commercial rules of course because it has no dedicated door, but I don't need that. The only thing I didn't realize when I got it was that you can't do an in frame rebuild on the isuzu engine because it splits at the main bearing joint. I think a cat engine was available in some models prior to 06 though. Backup camera was essential.
  11. Likes TeachMePlease, johfoster liked this post
  12. #69
    Jan 2004
    Halifax Nova Scotia
    1,809
    268
    Quote Originally Posted by tomjelly View Post
    Can you show us a few more pictures and details about your MegaHoist. Is this homemade or a commercial product. I did a google search dor megahoist but didn't get anywhere
  13. #70
    Aug 2007
    GA
    809
    140
    It WAS a commercial product, and they had a zombie website up until a few years ago. Its nice because the gantry cantilevers out 2' past the lowered tailgate, so you if you have a bulky item you don't necessarily need to remove the tailgate, or you can close it and go over it, and you don't need to do any modifications to the truck to mount it. rated 1500lbs. I bought 2 of them used at an auction in Atlanta a few years ago. I put one in my truck and sold the other to a guy in FINLAND who mounted it on the ROOF of his hummer expedition truck so he could stow his jet skis up there (!). There is another company who makes a similar one out of jumbo 8020 type stuff but I can't remember the name. I had to narrow this one to fit my dodge because the bed tapers at the rear
    Attached Thumbnails Attached Thumbnails megahoist-hummer.jpg   2020-04-08-10.54.50.jpg   2020-04-08-10.55.03.jpg   1500lb-megahoist.jpg
  14. #71
    Aug 2007
    GA
    809
    140
    If you are wondering how it got to Finland, I cut it apart for him and crated it so he could reweld it when it arrived! Had to be a heat treated crate to be allowed in to finland
    Attached Thumbnails Attached Thumbnails 20150921_123027.jpg   20150921_145910.jpg
  15. #72
    Jan 2004
    Halifax Nova Scotia
    1,809
    268
    I have found a very similar product to your Megahoist from a company called Ezy-Lift
  16. #73
    Jun 2006
    Near Seattle
    4,918
    3360
    1390
    ezy-lift (ezylift.com) and weightliftertruck.com have what appear to be competing products. ("A-frame hoist for pickup truck" seemed to be the right search term.)
  17. #74
    Aug 2007
    GA
    809
    140
    I remember seeing ezylift, looks like they have added a lot to their line. What might be most overlooked is that there are no structural mods required, huge advantage over a small truck crane
  18. #75
    Dec 2016
    Arizona
    234
    109
    134
    I had to move a stack of 20ft panels, and Purlins the other day. I would've had to drive 2hrs to get a trailer, but this cab/chassis NPR is here at the shop. I threw some dunnage on the frame rails and went for it. (Short trip through neighborhood streets only) Not sure I would try this again, though it worked out fine.
    Didn't pop any sweet wheelies unfortunately, another 30 panels on the stack maybe I wouldve been close haha.
  19. #76
    Jan 2004
    Halifax Nova Scotia
    1,809
    268
    Quote Originally Posted by johfoster View Post
    YouTube
    did you use this technique for the unload
  20. #77
    Oct 2009
    Oregon
    4,770
    5155
    2463
    Quote Originally Posted by Garwood View Post
    2003 F-350 4x4 6.0/ZF6
    I make a few parts for the 6.0's and 6.4's. Basically bought this truck because it is a crew ZF6 with power windows and nice interior. I have a 12 valve to go in it, but haven't managed to scatter the 6.0 yet. When the 6.0 comes out I will use it to demo the install of parts.
    With 385,000 miles on it I have done the following to keep it healthy:
    -Changed oil on a strict 65,000 mile schedule.
    -Changed oil filter once, it was the wrong filter, but it was expensive and I didn't want to go back to the parts store so I stuck it in anyway
    -Add water to the cracked degas bottle when it overheats from heavy towing (only locked up solid once, icy cold water got it freed up though)
    -Tied rope around waterpump shaft and each of the fan's blades to bypass the bullshit electric fan clutch
    -Used 2nd gear instead of trailer brakes a few times. Engine has no problem spinning way past where the tach stops at 5000
    -Replaced 3 driver's side unit bearings within one 20K mile span. I hate unit bearings (product in the works BTW)
    Overall, I love the truck except for the turning radius and the engine's performance. I have a set of '08 axles to go under this when the cummins goes in someday.
    The picture is why I love Superduties. That's a 3000+ lb 8' tall press brake behind the rear axle. I drove that 40 miles and it handled it just peachy.
    Just an update to this post.
    Sunday I finally successed at killing the 385,000 mile abused and neglected six-oh. The rope driving the fan blade stopped doing it's job up a 7% grade near MT Hood and with the temp gauge pegged I kept it to the floor and crested the top pretty toasty. I think I could have made it home if I stopped and added water, but I kept right on going (about 70 miles from home) and made it another 50 miles before the engine lost all oil pressure, lunched the turbo and we coasted to the shoulder.
    I had a feeling she was nearing the end and added roadside assistance to my USAA policy last week.
    Today I got the old beater C10 running again and ordered a couple grand in goodies for the 12 valve that will replace the six oh in 2 weeks.
    Is anyone else kinda sick like me and get excited when you scatter something so you can build it bigger, faster, stronger?
  21. Likes Ox, jancollc liked this post
  22. #78
    Mar 2006
    Vershire, Vermont
    2,215
    1475
    719
    ......Is anyone else kinda sick like me and get excited when you scatter something so you can build it bigger, faster, stronger?
    I've read about people like you on the internet.
  23. Likes Ox liked this post
  24. #79
    Jul 2007
    North Adams, Massachusetts
    386
    11
    33
    1997 Ford F-800 Lo-Pro rollback. 5.9 Cummins 6 Speed Spicer trans. Since acquiring this truck in 2016 I haven't driven a pick-up.
    Mark
    Berkshire Transmissions
    Attached Thumbnails Attached Thumbnails 73057733_2270527159743759_2220528848292806656_n.jpg
  25. Likes johfoster liked this post
  26. #80
    Apr 2005
    Brandon, MS
    836
    121
    172
    Quote Originally Posted by FirstEliminator View Post
    Mark
    Is that a potato digger beside the truck?
  27. Likes DrHook liked this post
