Source of Class 5 forklift forks ??
Likes Likes:  0
Results 1 to 9 of 9
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,016
    2599
    5458
    Default Source of Class 5 forklift forks ??
    Seems that every fork seller stops at Class 4......but I really need 5...standard hook type (as opposed to the round bar type) They must exist somewhere since the carriage is definitely class 5 and has forks on it now but they are too short in length.
    Oct 2012
    286
    106
    134
    Understanding Forklift Forks
    According to this Class 4 is as high as they go. After that it's proprietary to the mfr.
    The most common of fork is the ITA style which are divided up into classes. These classes define the carriage height that they can mount to.
    Class 2 = 16" Carriage height
    Class 3 = 20" Carriage height
    Class 4 = 25" Carriage height
    Typically any forklift from 1500-5500 lbs. will have Class 2 forks. 6000-11,000 lbs capacity lifts will be Class 3. 11,500-17,500 lbs capacity forklifts will be Class 4. After that, most forklifts use a shaft mount or propriety mount.
    Feb 2008
    Mishawaka, IN
    289
    26
    64
    What make and model are they going on?
    Sent from my E6810 using Tapatalk
    Mar 2009
    Eureka, CA
    3,488
    644
    1132
    We have used these folks before and they have a branch in the Ohio area.
    Forklift Forks - Forklift Fork Extensions | Cascade
    Stuart
    Oct 2012
    central Pa., U.S.A.
    297
    127
    66
    Yes, Cascade. cascorp.com pb
    Aug 2007
    GA
    634
    114
    May 2016
    Tennessee
    352
    54
    180
    We buy all our forks from these people- Forklift Forks & Attachments - Buckets, Booms, Grapples - Arrow MHP
    They can make you anything you want, and are reasonably priced.
    They may not guarantee a class 5 setup though. When you get past the capacity of a class 4, you start getting into the design limitations of the "hook" type setup.
    Feb 2019
    Alabama
    38
    Seems that every fork seller stops at Class 4 but I really need 5.standard hook type (as opposed to the round bar type)
    Dec 2009
    N. Calif.
    119
    7
    54
    Another vote for Cascade.
    I have used a lot of their products in the past.
