Thread: Toe Jack Recommendation
11-16-2020, 07:15 PM #1
Looking for something somewhat economical. Amazon Prime would be great too! 2+ ton toe capacity. Will need to position 7600+ lathe and lift my K&T 3K (8400 lbs) on to pipes. Thanks for any suggestions!
Justin
Sent from my Pixel 4 XL using Tapatalk
11-16-2020, 07:33 PM #2
I got one on ebay, I think they are under $100, pretty sure they all come from the same place....
Ja_cain liked this post
11-16-2020, 07:38 PM #3
Find a old rr track jack, will lift 7.5 or 15 tons...Phil
11-16-2020, 09:04 PM #4
This is what I bought last year but from a different seller. These are pretty nice for the DIY rigger.
Hydraulic Machine Toe Jack Lift (2.5/5 Ton)(5/10 Ton)(10/20 Ton) Track Lifting | eBay
11-16-2020, 10:06 PM #5
I've had good luck with Temco. Chinese, but with a US office; you can get a human on the phone easily.
11-17-2020, 01:50 AM #6
I have a few Temco products including a toe jack, and they seem to be as good as any of the cheap imports. I would buy it again probably if I needed another one.
11-17-2020, 08:31 AM #7
I've got a Temco too, 2.5 ton on the toe, 'bout $100 from ebay. My mill is only 3k lbs but it lifted like it wasn't there all the same.
11-17-2020, 09:42 AM #8
Ditto on the Temco. They have a nice controllable lower valve and a swivel pump handle, although you can get the jack in a position in a tight area where you can pump it no problem, but have to use pliers to lower.
Definitely worth the money
11-17-2020, 10:20 AM #9
