Toe Jack Recommendation
Ja_cain
Cast Iron
Feb 9, 2012
USA, Virginia
Looking for something somewhat economical. Amazon Prime would be great too! 2+ ton toe capacity. Will need to position 7600+ lathe and lift my K&T 3K (8400 lbs) on to pipes. Thanks for any suggestions!
Justin
Sent from my Pixel 4 XL using Tapatalk
I've had good luck with Temco. Chinese, but with a US office; you can get a human on the phone easily.
I have a few Temco products including a toe jack, and they seem to be as good as any of the cheap imports. I would buy it again probably if I needed another one.
I've got a Temco too, 2.5 ton on the toe, 'bout $100 from ebay. My mill is only 3k lbs but it lifted like it wasn't there all the same.
Ditto on the Temco. They have a nice controllable lower valve and a swivel pump handle, although you can get the jack in a position in a tight area where you can pump it no problem, but have to use pliers to lower.
Definitely worth the money
