Troubleshooting Forklift Transmission Problems
alskdjfhg
Feb 20, 2013
Houston TX
Old TCM 4000 lb forklift. When its cold, itll move fine. But once it warms up, it stops moving forward. Moves in reverse fine, and if you shift back and forth eventually it'll like "grab" and move in forward.
Any ideas whats going on? Burned clutch pack that works with cold oil?
Sent from my SM-G965U using Tapatalk
First to check is the brake disconnect valve .....connections may be worn ....next the tranny select linkages ........if that doesnt seem the problem,pull the tranny and rebuild it....Clutch packs dont burn in oil flooded trannys ,just wear,until they no longer apply .
How hard are parts to find on older TCM forklifts?
