Using Cribbing to Rig Machine Off Trailer - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Jun 2012
    Michigan
    8,809
    2608
    2989
    If you crib a trailer solid, off axles and springs.. then it is likely you can pinch or roller a fair size machine..perhaps 3000 lbs or so.
    Zips box idea seems good ..just stacking up would be tippisy...
  2. #22
    Oct 2013
    USA - OH
    241
    72
    58
    Quote Originally Posted by m16ty View Post
    I’m not 100% sure I understand your question but I’ll take a stab at it.
    Once you get past one side of the cribbing square, it’s stable enough. Of course the closer the cribbing is to the center of the weight, the more stable it will be.
    When building your “pig pin”, just make sure it stays level and shim if needed. Also, the cribbing is only as strong as as what is under it, make sure it’s built on a solid footing.
    You've got it, that's exactly what I was asking. Thank you!
  3. #23
    Oct 2013
    USA - OH
    241
    72
    58
    Quote Originally Posted by rbdjr59 View Post
    Most of the machines I have moved are set up to be lifted by 3 toe jacks. I have usually found openings or slots in the base where they fit and center the load properly. I picked up 4 ten ton toe jacks at an auction awhile back for a great price, $400. You will choke on the price for new ones.
    That's a ridiculous deal, holy crap!
    Thanks for all the photos, that really helps.
