Whats behind the nipple?
Results 1 to 10 of 10
    Jan 2019
    CANADA
    Ontario
    Default Whats behind the nipple?
    Hyster reach truck N40XMR which has can extend/retract the mechanism housing the forks- what is the nipple (is that the correct name?) for? Whats in the hole when nipple is removed?
    closeup
    Jul 2008
    South Carolina
    717
    312
    446
    It's a grease nipple. Like the name suggests, it's for greasing that joint. A grease gun is the correct tool for the job. As you can see it has been serviced due to the grease oozing out.
    Apr 2004
    Modesto, CA USA
    7,948
    1442
    Also known as a Zerk Fitting or just a Zerk.
    Bill D
  4. Likes Hodge liked this post
    Apr 2005
    Brandon, MS
    860
    125
    183
    Also know as an Alemite fitting or just an Alemite.
  6. Likes Hodge liked this post
  7. #5
    Jul 2008
    South Carolina
    717
    312
    446
    For a thorough bit of history on the nomenclature of the lowly grease fitting: From Alemite to Zerk: The History of the Grease Fitting - Equipment - Farm Collector
  8. Likes dalmatiangirl61 liked this post
  9. #6
    Dec 2009
    N. Calif.
    147
    10
    58
    It looks like the zerk on the far side is missing.
  10. #7
    Jun 2012
    Michigan
    12,139
    4102
    4353
    Q: What’s behind the nipple?
    A hole or passage way leading to the place that needs lubrication.
    A very handy device that allows one-way passage and to seal off unwanted contamination.
    Grease Zerk Thread Size Fitting Dimensions Drill Tap Chart – SilkRoadDance
  11. #8
    May 2006
    Illinois
    273
    104
    56
    Q: What's behind the nipple?".....I've been married 31 years! Where do I begin?!
  12. Likes pigpen60, tdmidget liked this post
  13. #9
    Jul 2007
    UNITED KINGDOM
    5,171
    3050
    2590
    Quote Originally Posted by Hodge View Post
    So the oil nipples on my Myford ML7 lathe are the genuine Zerk pattern, as opposed to the ball ended grease nipples on other machines. Fascinating!
  14. #10
    Mar 2008
    missouri
    35
    Never assume that just because its a zerk that it needs grease!
  15. Likes tdmidget liked this post
