Winching machine up tilt trailer question - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
  1. #41
    May 2014
    South Carolina
    835
    749
    199
    Pete; I'm looking at the same type trailer instead of building something. the one I'm looking at has a steel deck and double axle that's low. I'll have to remove the cage and do a few mods but it's in my price range at the moment.
  2. #42
    Dec 2009
    Rhode Island, USA
    344
    68
    40
    Neighbor applied his winch to a 2" reciever hitch which he welded at front.
    Could remove it and use elsewhere.
    I can see easily adding another socket further back, at the front of the
    tilting part, eliminating any concerns.
    Yes, on that yellow trailer there's enough room to permanently mount a winch just ahead of where it drops down in front of the fender (winch is on side facing middle of trailer) and put a small easy to remove snatch block in that receiver (in the center) that you mentioned. I would first look at Felling trailers, the FT series has a bunch in the size and design you want and I like the no ramp aspect.
  3. Likes digger doug liked this post
  4. #43
    Jan 2012
    75
    300
    17
    Quote Originally Posted by CBlair View Post
    As a side note to Bob's suggestion of a steel plate, we had to move a very heavy electron microscope and didnt have room for rollers and didnt want it to bounce around so we used the steel plate trick. It didnt budge but we lifted it slightly and threw some kitty litter on the ground and it slid like on ball bearings. This was on level ground to get it out of a truck and onto a level loading dock where there was no room for the forklift and the load at the same time.
    Charles
    Use glass beads,y0u'll push it on very easy
  5. #44
    Apr 2002
    Syracuse, NY USA
    9,799
    19
    608
    i like the glass bead idea. i have used ivory soap, you can mop it up. with the glass beads I suppose you can vac those up.
  6. #45
    Sep 2004
    Rugeley UK
    1,029
    24
    113
    The alternative to rollers is to use two pieces of steel flat bar, mine are 1 1/2" x 1/2" they will bend but they will provide a smooth surface to drag the machine up, an alternative is a steel sheet.
    PC
  7. #46
    May 2014
    South Carolina
    835
    749
    199
    Well I bought the trailer today, it was in better shape than what the picture showed. She had the maintenance records and original bill of sale. Now the work begins , I need to be done by Thursday night , Friday heading for Charlotte to move machines. What have you come up with Malicron ?
  8. #47
    Dec 2012
    NW Ca USA
    93
    12
    51
    Here is how I mounted a winch on my tilt trailer, works very well, I built the headache rack to mount the winch on just high enough to keep the cable from hitting the bed.
  9. Likes emcmike, digger doug liked this post
