would you.....
Results 1 to 11 of 11
Thread: would you.....
    Jan 2009
    midwest
    109
    6
    Default would you.....
    CALDWELL Portable Gantry Crane, 4000 lb., 8 ft. 6" - 40N127'|'HA90-2-10'/'8 - Grainger
    Use a gantry like this, in this fashion:
    The left upright was moved to the center, creating an over hang of about 50% of the beam. The right upright was chained to the floor using a couple anchors.
    The over hang was then used to pick a 500 pound load and wheel it out of a tight spot....
    Pass or fail? It worked without any incident but it looked sketchy as heck to me
    Oct 2009
    Olympia, Wa
    653
    306
    192
    I can't imagine 500lbs being too much for that crane, in that situation.
  3. Likes hermetic liked this post
    Jan 2009
    midwest
    109
    6
    Quote Originally Posted by Blazemaster View Post
    yea..just never saw someone chain something like that a floor... I am used to forklifts and mobility...
    Oct 2010
    Oregon
    5,158
    4457
    1877
    I have more than once set my somewhat larger portable gantry crane (Vestil 3T 10') with the beam overhanging a post by about 2', just out enough to put on a fixed beam clamp and have the chain hoist clear the post. The entire crane weighs roughly 1000lbs, so I have about 500lb (the shifted post doesn't count, but most of the beam does) with better than 4:1 leverage counterbalancing the load on the extended portion of the beam. You can do a 1,200lb lift in this configuration without the far end getting too squirrely, or the shifted post taking excessive load.
    With the 50% configuration, the real issue is the tie-down anchors, because the crane itself is doing much less to counterbalance the load. The 500lb load itself should pose no strength issue to the crane, but you may have to look at the design of the post-beam clamps as they may not have been designed for beam bending in this fashion.
    You can be sure the manufacturer will not endorse the use of the crane in this fashion, so any failures are between the user, the victims, and OSHA.
    Apr 2006
    Manchester, England
    8,446
    1252
    5381
    Have a couple of fat guys stand on the far end by the castors and you're good to go.
    Regards Tyrone.
  7. Likes adama, Derek Smalls liked this post
  8. #6
    Apr 2005
    Beaverdam, Virginia
    7,631
    743
    3619
    Seems real pricey for what it is, but that is Grainger for you.
  9. #7
    Dec 2004
    uk
    14,057
    4552
    6705
    Quote Originally Posted by Tyrone Shoelaces View Post
    Regards Tyrone.
    I much prefer counter weight to chain down, chain down especially to floor anchors if they have not been load tested is a far bigger unknown, also height of lift. if your just taking it off floor and spinning it, no one near it, the kinda risks are low.
    In the described setup, just how far in that leg is matters greatly, if at the 1/4 of the way to other leg you should be fine, putting the leg at the half way point, you really want the next size up gantry, sure the legs strong enough, but the beam is at arguably approach design capcity and in a dodgy setup, it pays to have a bit extra margin!
    Whilst its never safe to be under a load, the person that taught me the basics of staying safe kinda made it clear you should not be lifting something if you don't have enough confidence in the rigging to walk under it. That said, if you have a load cell and something heavy, a lot of dodgy setups can be proven and tested as a safe working solution. Theirs no magic, but yes its very much down to you to get it right and its on you if it goes wrong.
  10. #8
    Apr 2004
    Modesto, CA USA
    7,072
    1194
    Wallace gantry cranes are designed to overhang at one or both ends. I beleive the trolley can not be rolled past the leg attachment points so it has to moved to the end before the legs are moved around.
    I suppose it is similar to a gin pole crane.
    Bil lD
  11. #9
    Oct 2005
    16,053
    104 postings...
    Would You ???
    Try to compose a proper title ?
    Please try and follow the rules around here, it's not that hard.
  12. #10
    Jun 2004
    Melbourne Australia
    5,458
    Quote Originally Posted by Justsomeguy View Post
    You ought to be shot for such a shit title.
    This load, did it have just daylight under it, or was it 6 feet in the air? I like creative rigging. I'd doubt the de-rating of a double end support 4,000lb span would be bothered too much to become a cantilever at 500lb (1/8) at 50% span. I'd note max span of the beam was 9' 6".
    Your only issue is the attachment strength of the anchors. Given you have what is essentially a seesaw, those anchors need to see 500lb across the pair of them. 250lb each. Being lifting there should be a safety factor. Down here it's 6:1. To do it legal. So each anchor should be rated to 1,500lb pull out or concrete failure. Any amount of masonry products that will achieve this. Epoxy grouts etc, that only list concrete failure as its bond strength.
    We need a video of this lift that worries you
    Regards Phil.
  13. Likes tdmidget liked this post
  14. #11
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,374
    2853
    5648
    Closed due to utterly meaningless topic title
