1993 qt15( 202 low hydraulic alarm )
krgperformance
Jul 11, 2017
hello 1993 qt15 t-32
keep getting a 202 low hydraulic red alarm
can turn machine on and off and will clear it for a couple of parts then
will pop back up and wont clear pressure switch is a little low is there any way we can adjust pressure coming in?
and we cant ID chuck with it the 202 red alarm will pop up every time
thanks
some of the pumps had a pressure regulator what you could adjust. look for a locknut and a set screw. assuming you have already checked the internal filter if that is clogged it would produce same effect.
