2 z axis servo lag
Results 1 to 7 of 7
    Aug 2015
    Indiana
    18
    5
    Default 2 z axis servo lag
    I have a Mazak QT20N from time to time it alarms out with alarm #2 Z axis servo lag any ideas on this .
    Feb 2018
    DENMARK
    212
    12
    149
    I got the same problem with my mill. I will digg into it later this week hopefully
    Sendt fra min EML-L29 med Tapatalk
    Sep 2006
    Abingdon, VA
    3,564
    4805
    3459
    Random "servo lag" alarms on the older DC-drive Mazaks are indicative of a servo drive slowly going bad, or the power supply for the servo drives going bad.
    You can slow down your max rapids, that can help buy you time.
    The TRA-31 and TRA-41 drives, and the servo-drives power supplies (I forget the designation) are common on Ebay, purchasing one that was removed from a working machine is usually a good gamble.
    Good luck with it...
    ToolCat
  4. Likes Fabdawg liked this post
    Feb 2018
    DENMARK
    212
    12
    149
    Quote Originally Posted by cnctoolcat View Post
    ToolCat
    How do I check if it's a servo drive ?
    Apr 2013
    South Australia
    446
    120
    148
    Quote Originally Posted by Nikolaiownz View Post
    Swap the drives between the axis's. If the alarm follows the drive its a drive fault. If it stays with the same axis it's probably and encoder fault
  7. Likes cnctoolcat liked this post
  8. #6
    Feb 2018
    DENMARK
    212
    12
    149
    Quote Originally Posted by sudsy55 View Post
    Is the servo drive the print in the back ?
  9. #7
    Aug 2015
    Indiana
    18
    5
    OK thank you for the feed back , I have found some used X & Z Drives on ebay didnt know about the servo drive supply maybe be just search for servo-drive power supply ?
    slowing down the rapids i do that but just at the control I thought I have seen something before on some dip switches that needed changed am I thinking correct on this. one more question if I have to send out a board or a drive to be checked do you have any recomendations or do you just like to use Mitsubishi.
