marcin.warmuz
- Aug 7, 2019
Hello everyone!
New to this forum as a poster but have been lurking around for a while.
My company owns a VQC 15/40 with M2 controls. It did not (does not?) have EIA option in it. After doing some reading in these forums about people successfully adding EIA to their older controls, we obtained inexpensively an FX17 board as well as FX784-9 with EIA chips on it.
I installed the FX17 board and the FX784-9 but the machine would not power on. After that I decided to put the original FX784-9 back in it but with the EIA chips from the board we purchased (is it a total of 6 ROMS that need to be installed). Powered up the machine, changed the Y03 parameter to 128 to enable EIA/ISO and when machine is powered up, I get '22 SUM CHECK ERROR'. What am I missing? Are there any other parameters that need to be set? Is the 128 setting correct?
By the way, the machine functioned normally before. It was recently reinitialized after sitting idle for 6 months so new batteries on boards were installed and all the default parameters were reloaded from a disc, I used for few jobs it by programming it in Mazatrol and it works perfectly otherwise.
Thank you in advance,
Marcin
Marcin
