Advice on vqc 15/40
Results 1 to 13 of 13
    May 2016
    10
    Default Advice on vqc 15/40
    I looked at a vqc 15/40 that I am thinking about buying. When I got to where the machine was located it was under power but when I turned it on the screen lit up but would not boot up. I am not to familiar with mazak and did not check to see if the floppy drive was working or not. The tool changer was missing several sets of fingers. I also was not able to rotate the spindle by hand. Is this machine even worth bringing home, what would I want to try or look for if I go take another look at it, and what price range would I be looking at to get it back up and running. Thanks for any help or suggestions
    Apr 2013
    South Australia
    472
    128
    148
    What year, controller etc. Were there errors showing on the screen??
  3. Likes xa-mont liked this post
    Apr 2014
    AUSTRALIA
    633
    245
    157
    Quote Originally Posted by sudsy55 View Post
    Wot he sed Advice on vqc 15/40
    Sent from my HTC One using Tapatalk
    May 2016
    10
    The machine is a 1989 with a m32 control. There were no errors. The screen on the control had power but it was completely blank. I saw some other posts about an orange screen. The one on this machine was just a blue or purple. I tried pushing several soft keys and still nothing and there were not any led light on the control either
    Apr 2014
    AUSTRALIA
    633
    245
    157
    Did you try homing the axis? (z-, x-, y-, 4- hard buttons)
    It could have a stuffed screen. I've replaced the screen on my 20/40 m2 that only had like 8000 hours
    Apr 2009
    Thirlmere, NSW, Australia
    290
    401
    68
    When you say no LED lights on the controller... do you mean the face panel with the soft keys? Did you get to have a look in the electrical panel? There are some LEDs on the brain that tell you if things are functioning.
    Sent from my SM-T355Y using Tapatalk
    Sep 2005
    il.
    6,912
    49
    1435
    blue screen is bad
    a machine that will not boot up is worth a couple hundred over scrap at most.
    tell the seller you'll reconsider after he has had Mazak in and got the thing booted up.
  9. Likes sophtayl liked this post
  10. #8
    May 2016
    10
    Quote Originally Posted by xa-mont View Post
    I did try to home it and jog it with the hard keys but It wouldn't move. I did some research on here after I got home and read that it could possibly need to have a hard boot up done or that the floppy drive in the electrical cabinet could be bad.
  11. #9
    May 2016
    10
    Quote Originally Posted by sophtayl View Post
    Yes the LED's on the face panel with the soft keys did not come on. I did have a look in the electrical panel but the day that I looked at it I didn't know to look for the LED's on the floppy drive and I can't remember if there were any lit up on it. In hind sight I should have done some research before I went to look at it but the guy that was selling it told me a line of half truths and hole lies
  12. #10
    Apr 2009
    290
    401
    68
    I'm leaning with Wippin Boy here. If the LEDs on the soft keys didn't come on, (as in none of them) then there is likely to be more than the screen needing replacement. The Floppy drive LED wont be a good indicator.. Mine doesn't have a Floppy drive at all (VQC 20/50 M2 control).
    I would personally keep looking - unless the owner gets Mazak rep to give it a clean bill of health...
  13. Likes xa-mont liked this post
  14. #11
    Dec 2014
    New York
    816
    299
    199
    Keep on looking....I think this is one is not worth much, unless you want to do a total rebuild.
  15. #12
    May 2016
    10
    Ok thanks again for everyone's help
  16. #13
    Apr 2013
    South Australia
    472
    128
    148
    Check the 24volt supply. If that's fuked not much will work. Should be an LED on it. If not on then check power into it and out. Not sure if the m32 is the same setup as M2 but worth a look
