Alarm 398 Conveyor Overload "Off"
Likes Likes:  0
Results 1 to 9 of 9
    Nov 2015
    North Carolina
    8
    Default Alarm 398 Conveyor Overload "Off"
    Hi All,
    Does Anyone know how to reset this alarm on a Mazak VCN-510C-II? Thanks in advance.
    Ryan
    Nov 2016
    POLAND
    46
    Check relays. There's a thermal fuse on some relays.
    Sent from my D5803 using Tapatalk
    Nov 2017
    LATVIA
    63
    11
    14
    Take a look at electric circuit diagram of Your machine and find which magnetic contactor is used for conveyor (chip conveyor- right?). Then open an electrical box where all electronic/panels/relays are located and search for that magnetic contactor. It has an overload relay with current setting dial and reset button. Press it and everything should return to normal state.
    Sep 2005
    il.
    6,912
    49
    1432
    in a googled pic i found
    the only reversing contactor i see is right next to the control rack on top row in control cabinet
    one device hooked to the top of two devices
    the black thing is the reset
    maybe
    Jun 2013
    Houston, TX
    54
    60
    9
    Did anyone get this issue resolved?
    We have this alarm on our VCN-510-11 Mill this morning...
    Jan 2003
    623
    138
    202
    Quote Originally Posted by natemclain View Post
    Overload in the electrical cabinet. push to reset.
    May 2020
    Indiana
    47
    11
    As others have said should be in the main cabinet. You're looking for black relays with blue buttons I believe. Should say KM and some numbers. Make sure no jams in conveyors and/or augers and press a few of them. Probably not right to just press them at random but I've done it a bunch of times.
    Dec 2019
    CANADA
    Quebec
    rmedlin, well, I just wonder, how it's related to the rollers of such conveyors. And well, if it's all about rollers themselves, I would recommend you to check out specialized resources like with these gravity rollers which we've been getting for some of our conveyors, when we had some issues with them.
    May 2021
    Michigan
    16
    When my QT250 throws this alarm, I have to loosen the motor mount up on the conveyor to allow the chain to free itself. Then I can simply re-tighten the mounts back down and hit reset.
