I got an Integrex 400Y (2001) with fusion 640MT. Discovered that the B axis is off by about 0.16 degrees. I have read about people adjusting it both mechanically and in the controller but not how. (read a description somewhere but it must have been for a newer controller since mine only ha 1 MF and 1 machine button, and didn't find it in the menus what they wrote)
No idea of the machines history.
Between the spindle head and the X axis saddle (or whatever it's called) there is a ring. It has a marking to it and a marking on the spindle head. I can move that ring by hand more then a millimeter no matter if the B axis is clamped or not.
If i go to lock the B axis in either the horizontal or vertical position and it moves to either of those positions in a counter clockwise direction it sounds just normal but if i go to either of those positions in a clockwise movement, it makes an extra sound and i can see the ring move just a little bit (less than a millimeter). It is also visible that the B axis rotates a little bit when i clamp it and it makes that extra sound.
Anyone got any idea?
