These chamfering processes are driving me nuts!
I have a small 3/16 chamfer cutter (45*) that I have described as a chamfer cutter with a .19 diameter.
Im doing 2 ops to an aluminum part in the vise and want to chamfer the outside profile and some slots that go through the part.
On side one-
For the profile Chmf OUT works perfectly! Sweet!
For the slots (for bolts im sure) I used CHMF LEFT and while it did run, it overcut a the start point. Almost like it was on the wrong side of the line before it started the comp move.
Side two
For the profile, CHMF OUT works perfectly! Sweet!
For the slots, i can't get it to run at all. I get an illegal radius alarm with both IN and LEFT processes.
I took all my numbers from a cad drawing. I flipped the drawing over and moved the zero point and took all my new dimensions (for side 2) from the new zero. I have double and triple checked my cad numbers as well as what I typed into mazatrol and the numbers all match up.
WTF?!?!
Any ideas?
On side one-
Side two
WTF?!?!
Any ideas?
