benganboll
Hot Rolled
- Feb 23, 2015
- Sweden Östersund
I have successfully changed the range of speed on the driven tools on my QT10ATC from 0-1500 to 0-2500 by changing size of the pulleys and parameters.
But thinking of a different way of doing it on my Multiplex 620 so I dont loose torque.
Both my ST30ATC and MP620 hast the same FR-A500 driving the motor that at least looks the same, they also have the same pulleys but my ST30ATC has 0-3000rpm and my MP620 only has 1500rpm.
The different is a parameter on the FR-A500 that is setting the maximum frequency that is set double on the ST30ATC (I think it was set to 60Hz on MP620 and 120Hz on ST30ATC).
Could there be any damage on motor or drive if I double the maximum frequency?
The MP620 did have different options of 1500, 3000 or 4500 but that was done by different pulleys.
