Disconnect a Fusion 640T control for a long time.
Likes Likes:  0
Results 1 to 4 of 4
    Feb 2015
    SWEDEN
    593
    105
    282
    Default Disconnect a Fusion 640T control for a long time.
    I looking at a SQT28 with Fusion 640T control and I will need to store the machine for a few mounths before I have the space at my shop to install it.
    Is there anything that is battery reliant that should be backed up before I disconnect or is everything stored on the HDD?
    Feb 2006
    so cal, usa
    625
    232
    150
    I can't answer your question about the battery, but if the machie is under power now, it would be prudent to back all of the parameters and plc up before you chop the power.
    Nov 2016
    POLAND
    26
    I'd check the battery voltage and if low, install new one, should last you a year.
    My 640t has only 1 behind the screen.
    Sent from my D5803 using Tapatalk
    Feb 2015
    SWEDEN
    593
    105
    282
    Its under power now and battery is from 2015.
    If I backup prarmeters PLC it will be stored on the HDD?
