Editing speed and feed on mazak quick turn 6
Results 1 to 9 of 9
    Aug 2013
    Illinois
    10
    Default Editing speed and feed on mazak quick turn 6
    Is it possible for someone to explain how to edit the speed and feed on a Mazak lathe. It is a Mazak Quick Turn 6 and being a HAAS guy, I am unfamiliar with Mazak control.
    Feb 2015
    SWEDEN
    620
    107
    294
    I guess you are using Mazatrol and not EIA/ISO since you feel unfamiliar with Mazak.
    What control does your QT6 have Mazatrol T2, T32, T+ or even newer?
    Here is the T2: (I think all are the same)
    RV=rough cut speed
    FV=fine cut speed
    Feed=rough feed
    SRF=fine feed (Some kind of surface numbers where higher number is slower, and on newer controls than T2 you can also select feed/turn)
    Another feature that is good to know is that if you are not happy with your speed and feed and change them on the panel (%) during runtime and finds a speed and feed you are happy with you can press VFS and it will save it into the program.
    Jan 2013
    Plainfield, Indiana, USA
    1,794
    1372
    945
    Speed is expressed in Surface Feet per Minute so you don't have to include the diameter of your tool position in calculating RPM, Feed is in inches/revolution. Sort of like 'chip thickness' per rev.
    Most Mazak lathes are set up to change RPM with the cutting position of the turning tool, so rpm increases as you move toward center in the X axis.
    Jul 2006
    Arizona
    4,704
    18666
    4553
    He is really going to blow his mind when he discovers how to use the VFC button.
  5. Likes kevin66 liked this post
    Jun 2013
    Oregon
    1,559
    553
    930
    TPS-brain hemorrhage.
  7. Likes Philabuster liked this post
  8. #6
    Aug 2013
    Illinois
    10
    Thank you guys, all the info helped alot. Now I'm interested in learning what VFC is and does. Will do some google searches and see what I can find. Feel free to explain VFC also if you get time.
  9. #7
    Feb 2015
    SWEDEN
    620
    107
    294
    Quote Originally Posted by septooth View Post
    If you are not happy with your speed and feed and change them on the panel (%) during runtime and finds a speed and feed you are happy with you can press VFC and it will save it into the program.
  10. Likes Philabuster liked this post
  11. #8
    Jun 2013
    Oregon
    1,559
    553
    930
    VFC-velocity and feed control
  12. #9
    Feb 2017
    AUSTRALIA
    44
    21
    20
    I always called the vfc button the very f*cking cool button because of how it lets you play with the feed and speed then update the program with the new feeds and speeds.
  13. Likes benganboll, Philabuster liked this post
