Matt@Grizzly
- Dec 10, 2014
Was hoping someone might be able to help me out on figuring out the secret sauce to getting a EIA program running on my Mplus control.
I generated a 3D toolpath with Mastercam and posted the code, which it excepted in toolpath verification, but for whatever reason, it seems to continue to want to change tools, even though the specified tool is already in the spindle.
As I understand it, you have to write a tool change code as follows:
T19 T00 M6;
All of the examples in my manual show this format, though this is the first controller that I've had to add the "T00" to in order for it to function. When I didn't have "T00" in the line, it ran on toolpath verification, but alarmed out when I started to actually run the machine.
I suspect I'm having a parameter setting issue that is causing this, but it's uncharted waters for me at this point.
I bought this machine used and it had been years since I ran a Mazak and when I did, I only used Mazatrol. Now I've got some complex parts to run and I'm having a heck of time getting it up to speed with G-code.
Best as I can tell, my parameters are set to read all the tool offsets from Mazatrol, and from what I understand, you can do that even though you're running EIA programs?? The trick at this point is knowing where these parameters need to be set to get this thing fully functional with EIA and Mazatrol.
Any help would be greatly appreciated, as I'm pretty much at my wit's end at this point.
Thanks in advance for any help you can provide.
T19 T00 M6;
