Mazak Quick Turn Nexus 100, about 10years old. 640t control.
Pressing down on the foot pedal is not actuating the chuck. After a few pushes of the pedal, the chuck does eventually open.
Its a new chuck, cleaned and lubed.
Tried actuating with M code, but chuck M codes not an installed option on that machine
Im thinking its a bypass valve in the hydraulic system. Coworker thinks the pedal switch might be the issue. I hear it 'try' to actuate when the pedal is pressed.
Internet search said the actuating solenoid might be the issue. But that machine asked about was a 1984 QT15. Were they built similar?
Im not familiar with insides of these machines at all.
Suggestions?
Suggestions?
