Finish Stock
Likes Likes:  0
Results 1 to 5 of 5
Thread: Finish Stock
    Nov 2015
    Washington
    87
    6
    Default Finish Stock
    SQT-10, T-Plus
    I assume on the first line where you define your X finish stock, that is for both ID and OD.
    My question is what If I have a bore that I want to leave less stock because of tool size.
    How would I define that?
    Thanks!
    Jul 2006
    Arizona
    4,507
    18190
    4229
    You would have to write two separate ID boring processes--one with a rough only tool and one with a finish only tool.
    Say you have the X finish stock set to .010", but you only want .005" left in the rough bore.
    The process with the rough only tool will have false geometry ie you make the bore larger by .005" to compensate for the machine backing off .010". The finish tool will have the correct geometry in it's process.
    Later Mazak controllers allow you to control the finish tool amount by each process and not a global amount like the T+.
    Nov 2015
    Washington
    87
    6
    That's how I was going to do it but I thought "that can't be right".
    Thanks for confirming that.
    Jul 2006
    Arizona
    4,507
    18190
    4229
    Quote Originally Posted by Circuit 1 View Post
    No problem.
    Again, make sure you do NOT have a finish tool in the false geometry process or you will oversize the part.
    Nov 2015
    Washington
    87
    6
    Ya I can see where that can get you in trouble if you don't pay attention.
    Thanks Again!
