FR-SE - Over Voltage (Converter) Error
Results 1 to 6 of 6
    Apr 2009
    Thirlmere, NSW, Australia
    281
    393
    64
    Default FR-SE - Over Voltage (Converter) Error
    Hi Brains trust.
    trying to resolve an intermittent error with the FR-SE-2 spindle drive.
    The drive is tripping out on over Voltage (Converter) somewhat randomly.
    A week or so ago, I was in the middle of a cut and had the spindle drive trip on over voltage.
    I checked the waveforms and found 1 Waveform missing so I have ordered replacement DK434 driver chips and installed it today.
    Waveforms looks fine, including the response times etc.
    I ran the usual warm up cycle and all went fine.
    Then while running a very light cut (3000rpm - 12mm tool - 0.1mm/tooth feed - 1mm stepover/ 4mm DOC, it tripped out again on over voltage.
    I reset it and reran the cut again (sped up through air cutting)and it tripped again.
    I dropped the spindle speed to 2500 and feed down a bit also and it managed to complete the cycle ~ 25 mins.
    Then while I was thinking about the next test to debug the problem (with the spindle stopped and in home position), the error occurred again with the spindle stationary.
    I've had a look around and can't seem to find much on this.
    Has anyone come across this error and resolved it or have any suggestions on where to look?
    Cheers
    Mick
    Feb 2015
    SWEDEN
    516
    93
    242
    Replace all capacitors.
  3. Likes sophtayl liked this post
    Apr 2009
    281
    393
    64
    Quote Originally Posted by benganboll View Post
    I have only recently replaced them all. Maybe the joints weren't so great. Will revisit this as a starting point. Thanks mate.
    Cheers
    Mick
    Sent from my SM-G930F using Tapatalk
    Dec 2018
    FINLAND
    5
    Quote Originally Posted by sophtayl View Post
    Cheers
    Mick
    You could also try to set the decel time a bit longer.
    Sep 2005
    il.
    6,616
    30
    1209
    could be belt slippage
    Sep 2006
    Abingdon, VA
    3,305
    4329
    2992
    It may be time for new power blocks ("darlington transistors" in the FR-SE's) in the drive's base....
    You can source them new via Ebay.
    I have had luck upgrading the darlington's to actual IGBT's. As long as the physical size/shape is the same, it seems the electrical specs are close enough (actually faster/stronger) for the IGBT's to work fine.
    ToolCat
  8. Likes sudsy55, Philabuster liked this post
