Fusion 640M, can I drip feed from HD or memory card?
Likes Likes:  0
Results 1 to 2 of 2
    Jul 2008
    finland
    119
    6
    18
    Default Fusion 640M, can I drip feed from HD or memory card?
    M198 code which is used in Fanuc controls for calling a subprogram on a PCMCIA card does not seem to exist in Mazatrol 640M (the code exists but it's not the same). I tried to find the corresponding code, but there were none in the manual. Is it an option or possible at all?
    Jan 2019
    Kansas
    6
    What we have done is, run in "tape mode" off the HD area. I believe in the Data I/O page there is a soft key that selects the "HD area" and transfer the programs into there. I've also seen this... Use windows explorer to drag the file from the card into the
    "MC_Direct" folder on the hard drive. (I'm 99% sure that's what the
    folder is called, you may want to check in the manual). Once you've
    dragged it to the folder, it will show up in the HD Operation section
    under ">program>program file>change directory>HD Operation"
    Hope this helps
