Fusion 640M: Keep spindle on in manual mode
Results 1 to 6 of 6
    Jul 2008
    finland
    106
    5
    16
    Default Fusion 640M: Keep spindle on in manual mode
    When switching from MDI to handwheel after executing S1000 M3, the spindle stops, effectively preventing me from doing any quick manual work. Is there a parameter to bypass this behavior?
    Dec 2012
    Se Ma USA
    2,198
    179
    1198
    Mazatrol is your friend. Push the button to turn the spindle on. If you just booted up the RPM will be 0. It will hold 0 and not allow you to turn it. Use the button to raise the rpm. Select axis with knob? And push feed button as x1, x10, x100, or something like that. Push soft key for COMMAND screen and control will show big numbers. Use arrow keys to highlight any axis numbers you want and type in a number like 0 and handwheel will feed from there. More or less like that. I cannot repeat it because I do it without thinking about it.
    MDI has nothing to do with what I listed above.
    You can also feed by pushing any axis +- button and I sometimes do that when I want to face a long piece in a single pass. I can do it, but forget how.
    Oct 2020
    Missouri
    24
    50
    Do you have your door key removed? in order to have spindle rotating and hand jog an axis the door must be "closed"
    Nov 2012
    Wisconsin
    113
    287
    14
    Quote Originally Posted by ElCrasho View Post
    Or the setup switch must be on.
    Jun 2013
    Oregon
    1,869
    689
    1147
    Quote Originally Posted by EnderDRM View Post
    Or the safety switch has to be de-activated. I did not say that.
  6. Likes Scruffy887 liked this post
    Dec 2012
    Se Ma USA
    2,198
    179
    1198
    I cannot tell you how I did not deactivate door switches with pieces of #10 bent copper wire. Or how I did not get the machine to run with control cab open.
