Generating full nose radius od grooving sequence
Results 1 to 7 of 7
    May 2021
    Michigan
    16
    Exclamation Generating full nose radius od grooving sequence
    Hello, I am currently tasked to make some grooves! Usually quite simple, however I can not get rid of the chatter. So to avoid all the nonsense leading up to this, I'm looking to figure out how to generate a full nose radius balance groove on the OD. \
    Starting diameter is .263, finish diameter is .22, groove width accordingly is .059 and needs to be a .04 Radius in the middle. I've tried using a .08 wide FNR penta 34, and I think its causing too much tool pressure at 3" away from the chuck. I am using a tailstock with 100psi pressure on the front end with a #2 center in the front of the part.
    Is there a way to use lets say a .04 wide x .02FNR phorn od groove tool, to generate this? When I've tried, it usually comes out with 2 radii in the groove and a peak in the middle of it as well at the bottom. Looks neat, but its not what the customer wants.
    Thank you in advance!
    Jun 2013
    Oregon
    1,968
    712
    1196
    Since this is the Mazak forum I assume you are using Mazatrol. Post your grooving unit.
    Aug 2008
    Paso Robles, CA
    189
    72
    35
    How do you fit a 0.08 wide tool in a groove that is 0.059 wide? For that matter, how does a 0.04 radius go in a where a 0.0295 radius is all that will fit in a 0.059 wide groove.
    Jan 2007
    Flushing/Flint, Michigan
    10,762
    631
    8672
    From your numbers I get that your groove needs to look like this below.
    If true , no, can not be done with any FNR tool as clearing the corners impossible as this not a full radius groove.
    If I am wrong (which I usually am), print or drawing please.
    That wall only .0085 tall so if one cheated some tolerances on all cuts and rad size.
    You have a tailstock and say the cut 3 inch off chuck but how long is the part overall?
    Bob
  5. Likes cameraman liked this post
    May 2021
    Michigan
    16
    Thumbs down
    Quote Originally Posted by David Ferguson View Post
    Sir, I'm not burying that tool to its full width amount. You can use a .08 FNR groover to achieve a .059 simply by not allowing it to go past .059 worth of its width.
    May 2021
    Michigan
    16
    Mazatrol fusion 640T.
    IS this what you are implying?
    May 2021
    Michigan
    16
    There should be no flat walls in the groove. I will get a picture up shortly so yall can see the groove itself. This is not an easy task, but i know it can be done.
  9. Likes cameraman liked this post
